Wall Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 09:32 PM   #1
wall framing
is there a disadvantage of attaching the exterior wall studs directly to the sill plate,as opposed to framing on top of the subfloor?
jahni is offline   Reply With Quote
Old 02-21-2013, 09:36 PM   #2
Rewards Points: 12,876
Ya tons of air leaks, do not do it.
Old 02-21-2013, 10:16 PM   #3
Rewards Points: 332
Rim joist is better anchor for plywood to act as anti racking member. Rim joists is ready made blocking for joists from twisting. 8' wall with 8' studs are standard and less waste of wood.
carpdad is offline   Reply With Quote
Old 02-23-2013, 11:31 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
the height of standard studs will be an issue as well, you will be 3/4" short if building off of the framed floor system. for whatever reason when not wanting the whole sub floor put down- on some walls we have ripped 3/4" sub floor to 3 1/2" and put it down before putting up the wall. this requires blocking added into the floor system to catch the new sub floor that butts to the wall afterwards...
hand drive is offline   Reply With Quote
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 09:38 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 01:03 AM
