Wall Fixings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2004, 02:34 PM   #1
wall fixings
Hi,
I want to fix some shelves onto a brick wall. They should be able to hold at least 10 kg and assumed the best way would be to use 3.5mm screws which are 50mm long. Does it matter if the metal screw is longer than plastic screw plug? If the screw is longer than the plug should the plug still be put in the hole flush with the wall?
Thanks guys,
Allan
allandougramachi is offline   Reply With Quote
Old 05-17-2004, 08:14 PM   #2
Your best bet would be to use masonry anchors. The ones I've used are called tapcons.
hatchet is offline   Reply With Quote
Old 12-16-2005, 07:05 AM   #3
Tapcons are great for this application ...No mollies or plastic to deal with. They screw right in to the concrete/block and even come with the bit in the screw kit. they are a secure way to make sure things don't go bump in the night....you can find them at your favorite DIY store.
djames is offline   Reply With Quote
Old 12-16-2005, 03:48 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
And drill in the mortar, not the brick. MUCH easier.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-16-2005, 10:51 PM   #5
I'm just stirring the:
CGofMP's Avatar
If you know anyone with a hammer drill, even a small one your life will be made much easier as well.
CGofMP is offline   Reply With Quote
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
