Wall Damaged During Construction Of New Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 10:20 AM   #1
Wall damaged during construction of new home
I noticed this weekend that the ground wire had been pulled through my wall, damaging the stucco and metal mesh wire, "exterior gypsum sheathing" and the water barrier material. The inside already has the sheet rock up as well. I let the builder know about the issue, but they are building so many houses now they aren't as diligent as I would like them to be. What needs to be done to have this repaired properly? I don't want them to cut corners as I am paying a lot for this home.
Wall damaged during construction of new home-img_0597.jpg   Wall damaged during construction of new home-img_0612.jpg
jjh30 is offline   Reply With Quote
Old 06-23-2013, 11:05 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
thats an easy fix,, all they need to do is parge it
woodworkbykirk is online now   Reply With Quote
Old 06-23-2013, 11:30 AM   #3
What about the sheathing and water barrier, could this be an issue in the future if not also repaired?
Old 06-23-2013, 11:53 AM   #4
parging acts as a water barrier, its the same product that is put on the above grade portion of an icf foundation. if your worried about hte water proofing they can easily put a small bead of caulking in the crack first then parge over it
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (06-23-2013)
Old 06-23-2013, 12:37 PM   #5
Thanks!
Old 06-23-2013, 12:53 PM   #6
Rewards Points: 13,446
I'd be far more concerned with the sloppy way those wires where run in the first place.
Can you back up so we can see the big picture and see why there so many wires on an outside wall like that.
Old 06-23-2013, 01:47 PM   #7
I dont have a picture of the wires but I think they are for the power meter that ill be installed. They are about 6 feet hanging out from wall
Tags
damage , stucco , wall sheating
Removing a mobile home wall. chels Remodeling 4 03-22-2013 08:35 AM
wall construction weekendwarrior9 Building & Construction 2 09-10-2012 11:16 PM
Hello - Need help with Stone Retaining Wall Construction morarview Concrete, Stone & Masonry 3 04-11-2012 09:19 AM
proper wall construction 1ryan1 Building & Construction 10 03-11-2011 07:07 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
