#1 |
wall to concrete floor
can a wall be atteached to concrete floor by drilling a small hole in the bottom plate into the concrete and then placing a piece of electrical wire in the hole and driving a 31/2 nail into the hole ?
#2 |
Why not use tapcon screws?
#3 |
Renovations contractor
Look in the section of your hardware store that has anchor bolts and you'll find various correct methods for securing the sill plate including the screws indicated by the last responder.
Home Renovations & Repairs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Vancouver to Whistler & beyond |
#4 |
to directly answer your question, yes - it can,,, however, that calls for re-defining ' attached ',,, no one would use that method in my home - even me,,, however, exigent circumstances often change things in life - IF it were 1 or 2 tapcons that were delaying a weekend project AND there wasn't any apron stores open at 0-dark-thirty when i was doing the work AND if i promised my bride, nagzilla, do it right when stores opened, i'd do it, too
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 | |
bend the wire in half and stuff the loop into the hole... tie wire works best.
I agree that it isn't the best method, but it does work. Pressure treated plate with sill gasket under it.
#6 |
+1 make sure you put the sill gasket under it or it will rot over time.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional. |
| Display Modes | |
| Basement Concrete Wall Framing Against Stairs | Epicsoccer | Remodeling | 7 | 01-13-2013 04:11 PM |
| WET concrete wall under TOP floor bathroom window---how to stop? | Dyoung | Building & Construction | 8 | 02-13-2010 11:14 PM |
| how to determine if wall is load bearing | Tonglebeak | Building & Construction | 26 | 01-21-2010 12:26 AM |
| cold concrete floor | RuthP | Flooring | 4 | 02-03-2008 11:13 PM |
| Join Wood Cyc Ramp to Concrete Floor | Bigboots | Building & Construction | 3 | 11-27-2007 10:52 PM |
