Old 04-01-2009, 11:53 AM   #1
Default Wall cap for masonry wall
We are building a courtyard and are making a 32" sitting wall surrounding it. The wall will be a 8" stucco wall. We are trying to see if a 10 1/4 " wall cap should be used or should we use the 12" wall cap.
The concern is that the 12" wont look proportionate and that it may become unmortared over time.
We are using the Sterepstone inc classic wall cap.
Thanks for any advice.
cliffslocal is offline   Reply With Quote
Old 04-01-2009, 03:59 PM   #2
10 1/4 will look better. But this is a bit high for a sitting wall. Sitting walls are 18" high.
More On This Topic
This is Ben Ingham with Expert Village talking about a walk out basement. What I would do with this exterior is stucco. I have stucco before which is just a mixture of water and cement pour in cement and sand and you just put it on there. I understand... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be taking you through the process for preparing our wall. The wall that we have here is made of cinder blocks. A lot of times along these mortar joints it will crack and/or leak so... Read More »
Hi! I’m William Myers with Subaru for Expert Village. We’ve checked your battery level, now if you had to add water to your battery all you would do is remove the cap and add your distilled water right in there. That’s how you would add... Read More »
Ok in this segment we're going to get a little bit more into weapons. When you are first starting the game and you come down from the security room and you come down in the main entrance of the mall, like I showed you before, charge the battery to your... Read More »
Hi. I'm Jen from Clay Cafe and on behalf of Expert Village I'll be showing you how to take your ceramic piece from start to finish. In this clip I'd like to introduce you to what glazes actually out there that you can paint your piece with. First off the... Read More »
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 05:29 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 07:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 05:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
