Wall Bracing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 11:05 PM   #1
wall bracing
in a tilt-up construction commercial unit I am building 3 - 7'2' partition walls. I am told that they must be supported by bracing every 4' staggered to the roof joists. The drop ceiling height is 10' and there is another 10' to the interior roof. What type of bracing is required and how is it required to be attached to the metal roof joists according to the calif building code 2007
Patrick P is offline   Reply With Quote
Old 05-18-2011, 06:47 AM   #2
Stay-at-home GC
Magic.
Phew, seriously? If I'm reading you right your trying to brace a partition wall that is 3' shorter than the finished ceiling height and 13' shorter than the joists?
So you have a 3' gap between the top of your wall and your drop ceiling? ala Cube Land
I have seen commercial spaces with metal "rods" that run through the drop celing along the partition walls, but it beats hell out of me about their source or install.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-18-2011, 01:28 PM   #3
Tizzer's Avatar
Rewards Points: 460
Nothing personal, but how did you get this commercial job if you don't know what you're doing? No set of plans on the jobsite?
Tizzer is offline   Reply With Quote
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
