Old 02-23-2011, 04:14 PM   #1
Question
wall below low deck ledger
my deck is only about 20" and on one end it rests on my shed and there is a ledger there. the area below the ledger is only about a foot high and i was only gonna put house wrap over the sheathing, without siding as it won't be exposed. was wondering if that will be sufficient moisture protection or should i apply something else.
thanks
Old 02-23-2011, 11:37 PM   #2
Woodtick
House wrap wont do the job. It will be degraded by ultraviolet and even the gentlest of breezes. It doesnt have to covered by the most expensive of sidings. Just by something that wont dissolve.Whatever it is should run up behind the deck ledger. The top of the ledger should be flashed. This will keep water from getting behind the ledger and damaging the structure it is attached to. House. Shed. Whatever. It's your house. Protect it.
ccnvchris is offline   Reply With Quote
The Following User Says Thank You to ccnvchris For This Useful Post:
amakarevic (02-23-2011)
Old 02-23-2011, 11:59 PM   #3
it's just a shed ...
Old 02-24-2011, 09:22 AM   #4
thanks
Post a picture of the area you want to protect.
Ron
Deck Ledger needed for non-load deck attachment? Clutchcargo Building & Construction 4 06-18-2010 09:20 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
How do I attach a ledger (for a 2nd story deck) if there is no rim joist? jrdamien Building & Construction 11 08-05-2009 07:25 PM
Attaching deck ledger to cantilever ram80ran Building & Construction 13 04-18-2009 01:29 PM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 01:41 PM
