Is This Wall Bearing? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 09:32 PM   #16
I ask the impossible!
Rewards Points: 692
The floor joists with nothing else attached to them may not be an issue, the single floor joist, though, where the perpindicular floor joists attach is probably your greatest likelihood for having issues. That alone probably needs the support, and supporting evidence of that is the fact that on the other side where you don't have a load bearing wall, the corresponding header is shown as triple in your 3D from the original post.
Being a row home, if you know any neighbors maybe you can see if they have similar interiors and if the same wall is in place or not. If you're a recluse, you could look online to see if you can find other similar homes on the street which are listed for sale or recently sold, and see if you can see interior photos that might show if they have or don't have this load bearing wall.
What I was alluding to earlier was an engineer might be able to say if you could make up the strength with solid blocking, but I wouldn't have a clue how much strength could be added by that.
WillK is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
