Wall Access Tips? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 12:53 PM   #1
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Wall access tips?
I am framing my basement and have come around to some items I need access to once the drywall goes up. Main water pipes, drain access, cables, telco system, ect. Anyhow what is the best way to leave easy access to these areas but not have it look like crap when its done? And no I am not doing a drop ceiling!
Thank you,
Mark
Taipans is offline   Reply With Quote
Old 03-07-2008, 01:38 PM   #2
Depends
If you need to access on/off water switch which you need to turn on/off all in winter/summer time, I recommend you install those stronger metal door.
if you need to access those other things which you don't access them in a regular basics... those plastic white cover is the best... just cut out a smaller square hole in the drywall, then this cover insert into the hole with self mounting spring....
KUIPORNG is offline   Reply With Quote
Old 03-07-2008, 02:30 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The Big home Improvement Stores (like HD) carry paintable, plastic, clipped, access doors. With these, all you have to do, is cut out an opening (that corresponds to the panel size) in the sheetrock, and insert the panel. Paint them the color of the wall or ceiling, and they blend in very nicely.
With the metal access doors, you need to frame in the opening, and use screws to mount the door. They remain very visible due to their design.
Pictures of paintable plastic access door:
- Build Well -
Old 03-07-2008, 02:46 PM   #4
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Nice Atlantic! I had no idea those even existed! That takes care of my problem as I have a few spots they would come in handy! I will already have the electrical box showing, which sucks. Wish that would of been installed on the other side of the house.
Old 03-07-2008, 03:08 PM   #5
Custom Cabinet Maker
Just turn the house around
skymaster is offline   Reply With Quote
Old 03-07-2008, 03:18 PM   #6
Beer Advocate
Taipans's Avatar
Rewards Points: 150
That might be to big a job for me, I should call around tonight and get some quotes!
Old 03-07-2008, 03:28 PM   #7
Pc of cake call and I will help ya, one day job LOL
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
