Walkdown Basement Entrance Needs Covered - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 08:33 AM   #1
Sort of an awkward setup and I'm having issues visualizing a solution to this. Hopefully I can explain this accurately without taking a picture.
Looking at the back of the house:
Porch on the left, cement base about 3'6" high, 6' wide. Very flimsy metal railing perimeter.
To the immediate right of the porch, starting at ground level, cement stair case down to basement. Left wall of stairwell is the porch foundation, right wall is cinder.
The right wall of the stairwell is about 2 ft high above ground level.
There is a drain at the bottom of the stairwell and i had it checked before winter, and will have it checked again before we get hit.
Right now, we have this opening covered with a large tarp. Very unattractive, thought it does the job. I would like to relieve this method as it gets filled with spiders, webs, and growth from being covered.
Any ideas?
The only requirement I need to keep in mind is rain runoff, i need to make sure whatever i use as cover as a degree of tilt to allow rain to run off away from the house.
asmealio is offline   Reply With Quote
Old 12-06-2012, 09:51 AM   #2
Rewards Points: 13,712
Really need that picture for this one.
Old 12-06-2012, 10:02 AM   #3
I'll post one tonight...thanks for chiming in!
Old 12-06-2012, 10:22 AM   #4
Rewards Points: 3,628
Are you looking for something like this??
http://www.bilco.com/foundations/sto...?product=1PE-1
Canarywood1 is online now   Reply With Quote
Old 12-06-2012, 10:27 AM   #5
I wish. But can't be used because of the stairwell walls.
Like the gentlemen said...i need to post a picture
to give you a basic visualization:
[ p ]/s\[w]
p=porch
s=stairs
w=wall
the bracket(wall) on left of stairs is about 3.5' high while the bracket (wall) on right of stars is only 2' high
stairs start at ground level and go down to basement
I will post pictures tongiht
Old 12-06-2012, 11:03 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,358
[ p ]/s\[w]
p=porch
s=stairs
w=wall
Ayuh,.... A picture will be nice,...
I visualize a door, hung off the left wall, closin' to the right wall, with pitch from the house, to the outside for drainage...
Plywood might work, but I see fiberglass corrugated panels will be lighter, better lookin', 'n easier to open, 'n close...
Oh,... 'n ya make no mention of the dimensions of the opening...
Bondo is online now   Reply With Quote
unfinished basement comfort tls1 HVAC 44 09-16-2012 10:44 AM
Basement wasls, vapor barrier , options for what i have to work with bf514921 Building & Construction 3 07-12-2012 11:26 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
