-   -   Walkdown Basement Entrance Needs Covered (http://www.diychatroom.com/f19/walkdown-basement-entrance-needs-covered-165732/)
asmealio 12-06-2012 08:33 AM
Sort of an awkward setup and I'm having issues visualizing a solution to this. Hopefully I can explain this accurately without taking a picture.
Looking at the back of the house:
Porch on the left, cement base about 3'6" high, 6' wide. Very flimsy metal railing perimeter.
To the immediate right of the porch, starting at ground level, cement stair case down to basement. Left wall of stairwell is the porch foundation, right wall is cinder.
The right wall of the stairwell is about 2 ft high above ground level.
There is a drain at the bottom of the stairwell and i had it checked before winter, and will have it checked again before we get hit.
Right now, we have this opening covered with a large tarp. Very unattractive, thought it does the job. I would like to relieve this method as it gets filled with spiders, webs, and growth from being covered.
Any ideas?
The only requirement I need to keep in mind is rain runoff, i need to make sure whatever i use as cover as a degree of tilt to allow rain to run off away from the house.
joecaption 12-06-2012 09:51 AM
Really need that picture for this one.
asmealio 12-06-2012 10:02 AM
I'll post one tonight...thanks for chiming in!
Canarywood1 12-06-2012 10:22 AM
Are you looking for something like this??
http://www.bilco.com/foundations/sto...?product=1PE-1
asmealio 12-06-2012 10:27 AM
I wish. But can't be used because of the stairwell walls.
Like the gentlemen said...i need to post a picture
to give you a basic visualization:
[ p ]/s\[w]
p=porch
s=stairs
w=wall
the bracket(wall) on left of stairs is about 3.5' high while the bracket (wall) on right of stars is only 2' high
stairs start at ground level and go down to basement
I will post pictures tongiht
Bondo 12-06-2012 11:03 AM
[ p ]/s\[w]
p=porch
s=stairs
w=wall
Ayuh,.... A picture will be nice,...
I visualize a door, hung off the left wall, closin' to the right wall, with pitch from the house, to the outside for drainage...
Plywood might work, but I see fiberglass corrugated panels will be lighter, better lookin', 'n easier to open, 'n close...
Oh,... 'n ya make no mention of the dimensions of the opening...
