Walk-out Basement/water Leaking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 07:33 PM   #1
Walk-out basement/water leaking
Hello,
I have a walk-out basement & I've noticed water leaking in,
from underneath the door, during the last 2 rainstorms.
I initially thought the threshold needed work, &
this still may also be the case.
I see today, the drain in front of the basement door became plugged,
with debris during the storm.
I try to keep the drain & area free from debris.
This storm was violent & debris collected during the raging storm, &
I believe caused water to backup over the threshold, & leak in to the basement.
Please share your ideas with me, to help make a more watertight
threshold & basement, &
a way to make the drain more clog resistant.
Thanks In Advance,
Uni
Walk-out basement/water leaking-20130629_194454.jpg   Walk-out basement/water leaking-20130629_194523.jpg   Walk-out basement/water leaking-20130629_194541.jpg   Walk-out basement/water leaking-20130629_194552.jpg   Walk-out basement/water leaking-20130629_194808.jpg
Unicornz0 is offline   Reply With Quote
Old 06-29-2013, 08:02 PM   #2
DIY staff
Rewards Points: 7,174
A couple of suggestions--cheapest first--
A.Remove the threshold clean and wire brush the back and the concrete--then reset it with plenty of silicone caulk under it---
B.Same as above but add a riser made of 3/4" PVC board,siliconed to the concrete---then reset the threshold and cut the door to match.
C. Cut the concrete open and replace the little round drain with a long trench drain---
roofingquotes (06-29-2013)
Old 06-29-2013, 10:20 PM   #3
roofingquotes's Avatar
I would go for suggestion B. As long as its the cheapest.
roofingquotes is offline   Reply With Quote
The Following User Says Thank You to roofingquotes For This Useful Post:
oh'mike (07-01-2013)
Old 06-29-2013, 10:32 PM   #4
Thanks,
Is there a device which will fit over this round drain, like an inverted drain strainer, making the drain more resistant to being covered & plugged with debris?
Thanks Again,
Uni
Old 06-30-2013, 06:10 AM   #5
DIY staff
Yes there is---look in the drain pipe section of the store, they are used in window wells---tripping hazard--but if that entry is seldom used then go for it.
Windows on Wash (06-30-2013)
Old 06-30-2013, 06:41 PM   #6
Old 06-30-2013, 07:33 PM   #7
DIY staff
I had one that was deeper than that and I added a wood slat cover for the whole pad---that caught the leaves and made the deep well shallower and easier to walk on--
that well was about 7 inches deep---much deeper that yours---
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
