Old 08-06-2011, 01:57 AM   #1
wait time from first thinset coat to redguard app
Never did ceramic tile install before,,can you tell? How long from taping corners seams and screw holes do you wait ,,,cure if you will,,before applying redguard??? one coat only or is it like drywall and require multiple coats of thinset on tape and seams???
this is in a rental that one responsible male says he can take a bath in tub without splashing walls,,how much time between tape thinset coat and trying a bath,,,want it at least finger touch dry??? we are having high humidity and up to last week high temps BUT central air is up and running fairly often,,,thinking apply in morn, will it be decent dry by evening???
And while we are on it,,is there a cure time from last redguard install to applying ceramis tile???
thanks for all info--d--
4just1don is offline   Reply With Quote
Old 08-06-2011, 03:22 AM   #2
What are you taping - drywall around a tub/shower? If yes, should not be drywall - rather cement board of some sort.
____________
Vince
Old 08-06-2011, 04:42 AM   #3
sorry , forgot to add,,it is cement board for ceramic tile install. and yes I did get the cement board tape. guessing I am using that also on my cement board to plaster transition on edges also. I have rock lath plaster walls.
Old 08-06-2011, 06:09 AM   #4
Super Moderator
12 hours---
oh'mike is online now   Reply With Quote
Help! Fuzz in final poly coat roxksears Flooring 2 11-03-2009 02:19 PM
Is one coat of stain enough? hayzen Painting 8 09-03-2009 11:13 PM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 12:43 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
Time for Painting Second Coat Dougit Painting 1 01-27-2008 10:33 PM
