Wainscot Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 01:06 PM   #1
Wainscot Question
My home has 6" base with a half inch top edge 9 ft ceilings and the wife wants to put either 32" or 48" panels in our hallway, I can see installing it over the DW but is there a wood product thin enough to install like 1/4" to keep from taking off all my base? Its about 14' long hallway.
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
Old 02-02-2013, 02:16 PM   #2
Rewards Points: 636
could just do wall frame wainscoting
http://www.google.com/search?q=wall+...w=1600&bih=775
http://www.thisiscarpentry.com/2012/...ing-buildcalc/
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-02-2013, 02:20 PM   #3
Rewards Points: 77
Sure, they have 1/4" plywood/luan panels. If you take a picture, that might help.
Personally, I would take the baseboard off, tidy it up as much as possible, install the wainscot and then place the baseboard back on.
Here's a pic of what I did. I used 1x8 for the bottom of the wainscot so the 6" you have should stack nicely so it can be recycled. This pic is before the quarter round, caulk and touch-up paint, but shows the 4" trim stacked on it. The 6" should look just as nice I'd think, depending on the style.
dengle is offline   Reply With Quote
Old 02-02-2013, 02:59 PM   #4
Rewards Points: 150
If u want to leave baseboard that bad u can just over apply trim on Sheetrock with a chair rail above using Sheetrock as rails and stiles
kaschmid3 is offline   Reply With Quote
Old 02-02-2013, 03:09 PM   #5
this is how i did our dining room with just molding and chair rail
Old 02-02-2013, 03:22 PM   #6
That's not a bad idea, picture frames with trim and leave base alone. Thx
Old 02-02-2013, 03:59 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,104
whats your style of the baseboard, if its simple square stock with a base cap id remove the cap only, then set the wainscotting on it then put a new thiner basecap back on to hide any gaps where the panelling sits on the base..
woodworkbykirk is offline   Reply With Quote
wainscot above baseboard hot water heat scroff Remodeling 7 09-11-2012 11:57 AM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
