W-Beam Post Or 6x6 Post.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2013, 06:58 PM   #1
W-Beam Post or 6x6 post..
I believe a 6x6 post can only have a maximum height of 14'. I need something near 16'. Instead of using a pressure tread 6x6 post, could I use a W-Beam? Any recommendations regarding to the appropriate size? Thank you.
Cruizer is offline   Reply With Quote
Old 10-18-2013, 07:02 PM   #2
Framing Contractor
Rewards Points: 118
If you are needing a post of that length, you would be a fool not to consult with an engineer
sixeightten is offline   Reply With Quote
Old 10-18-2013, 07:27 PM   #3
I'll only need it on one corner of a 9'x12' patio. I can support the patio along a preexisting 12" thick reinforced concrete wall except on one end. I plan on using 2-2x12 beams. If anything I'm over-designing. I don't mind over-designing when it comes to the steel beam too.
Old 10-18-2013, 07:57 PM   #4
Civil Engineer
Rewards Points: 4,698
Are you building a deck or a patio? If you are building a deck, what code are you designing to? Your post is so vague I can't tell what it is you are trying to accomplish, and I don't understand your basis for concluding that a 6x6 post is limited to 14 feet. Are you concerned about buckling, or did you read about the 14 foot limit in a local code book, or perhaps in an on-line article?
Daniel Holzman is online now   Reply With Quote
Old 10-19-2013, 12:42 AM   #5
I'm building to NY code. What I'm building is a patio that adjoins to my house and reaches to my deck that is 9' away. Yes, I did read online that 6x6 posts can have a max height of 14' according to certain code. Not sure about NY, but either way I feel more comfortable using steel for such a height. Possibly a 1/4" thick, 5-1/2" diameter steel column. I would have the shop weld a 1/4" plate to the bottom of the column for the footing and a 1/4" steel U-Channel Flange at the top to accommodate the 2-2x12's or possible 3-2x12's.
Old 10-19-2013, 02:53 AM   #6
Bill Kearney
Rewards Points: 1,174
Post a picture of the area. What you've posted doesn't really seem to explain the situation.
wkearney99 is offline   Reply With Quote
Old 10-19-2013, 01:13 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
for what it's worth ....
According to publication by the American Forest & Paper Association a 6x6 douglas fir No. 2 wood column at 14' can handle 120 square feet of tributary load (when rated for 60 psf total load). at 17' it is rated for 84 square feet of tributary load.
Hopefully you are no where close to the ocean or salt water.
make sure you're steel column is galvanized or coated if exposed to weather.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-24-2013, 11:01 AM   #8
Rewards Points: 35
You could always brace the 6x6 wood post in 2 directions with a knee brace. It should allow you to increase the length a couple feet.
However, If I was in need of a 16' high post, I'd definitely be in contact with an engineer.
d189379 is offline   Reply With Quote
Old 10-24-2013, 11:03 AM   #9
Rewards Points: 35
Something like this...
http://www.wiseowljoinery.com/projec...am/corner1.jpg
Column location for LVL Beam Perry401 Building & Construction 1 09-10-2013 11:27 PM
Replace post between roof and concrete patio. clintonb Building & Construction 4 05-27-2013 06:10 PM
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 11:50 AM
beam extends beyond post jklingel Building & Construction 10 06-14-2010 10:20 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
