Old 02-24-2013, 11:16 AM   #1
virginia building code
Is there a virginia building code for the cabinet height above gas stove
2 Home Owners is offline   Reply With Quote
Old 02-24-2013, 11:23 AM   #2
Should be the same everywhere. 18".
Old 02-24-2013, 11:32 AM   #3
MarginallyQualified
allow for the exhaust hood height too
Old 02-24-2013, 03:31 PM   #4
Joe, isn't 18" a bit short? Usually the bottom of full height wall cabinets are set at 54" which is 18" above the countertop height. A gas range should be installed to manufacturer's specifications, the specs will indicate the clearance to a combustible surface above. I think that is usually 30" from the top of the gas range to the bottom of the cabinet above. What do you think?
TheCamper is offline   Reply With Quote
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 07:13 PM
building code bikswahla Building & Construction 7 04-10-2010 04:23 PM
Simplified/Summary CA Building Code? acerunner General Discussion 5 03-18-2010 10:46 PM
Finding a copy of the 2006 International Building Code WFO Electrical 2 07-11-2009 08:21 PM
Buidling code for deck and nailing schedule Jozee Building & Construction 7 10-01-2008 01:46 PM
