-   -   Vinyl windows and brick molding (http://www.diychatroom.com/f19/vinyl-windows-brick-molding-78403/)
a7ecorsair 08-10-2010 03:38 PM
We are in the process of building a new house that will have vinyl windows and steel siding. I was discussing the methods of finishing around the windows with the builder and the normal way is to cover the nailing flange with the J channel and siding. If the window would ever have to be replaced, the siding would have to come down first. He said that if I'm that concerned about future maintenance then vinyl brick molding or something similar could be used to cover the nailing flange with the J channel against this but of course it would increase the construction costs. Am I being over concerned about this?
firehawkmph 08-10-2010 08:22 PM
A7,
The vinyl brickmold sounds like a good way to go. Steel siding would be tough to cut out to change out the windows. And let's face it, twenty years down the road, you may be changing some out.
Mike Hawkins:)
Tom Struble 08-10-2010 09:04 PM
most new construction vinyl window are available with a snap on exterior trim in different styles and colors
a7ecorsair 08-10-2010 09:13 PM
So this "snap-on" trim covers the nailing flange? Removing the trim would allow access so the window could be replaced if needed?
Tom Struble 08-10-2010 09:54 PM
yes it would
