Vinyl Siding, White Spots? - Building & Construction - Page 6 - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 03:55 PM   #76
Tom Struble's Avatar
Rewards Points: 2,002
try some softscrub,just alittle and don't rub too hard,rinse well and see what happens
Tom Struble is offline   Reply With Quote
Old 06-10-2011, 03:58 PM   #77
So far I have tried vinegar and once I tried siding wash...nothing.
dinosaur1 is offline   Reply With Quote
The Following User Says Thank You to dinosaur1 For This Useful Post:
Tom Struble (06-10-2011)
Old 06-10-2011, 04:28 PM   #78
may need alittle abrasive action,you can also carefully try ajax or some comet,go gently with the ''grain''
Old 06-10-2011, 04:38 PM   #79
So ajax and what can I try scrubbing it with..a wet towel?
Old 06-10-2011, 04:45 PM   #80
kwikfishron's Avatar
Rewards Points: 1,018
Originally Posted by dinosaur1 View Post
Right now I have 2 options. Paint it or try and clean it.
I can always use a light color latex paint, which will flex with the vinyl's movement.
As far as cleaning goes....not sure what I can try to use to remove the spots. I don't think there is anything I can use.
I’d replace the panels before I’d paint them.
All of the channels, corners and other prep work is done, that’s most of the work. Just replacing the panels is easy and would probably cost less than you think.
kwikfishron is online now   Reply With Quote
Old 06-10-2011, 05:40 PM   #81
yea a wet towel but don't scrub too hard
Old 06-10-2011, 06:12 PM   #82
Sheesh…81 post and now back to page one. Didn’t you already try all of this Dino.
Old 06-10-2011, 06:27 PM   #83
yep, I sure did.
Old 06-10-2011, 09:06 PM   #84
well i'm done
Old 06-12-2011, 09:36 AM   #85
It's all over our home though.
Old 06-12-2011, 10:13 AM   #86
Your options are pretty limited at this point.
1) Replace it.
2) Live with it.
3) Paint it.
I’ve have only seen a couple of painted vinyl houses and I wasn’t impressed. The seam movement is an issue. If you paint it this summer I guarantee next winter you won’t like what you see. Defiantly don’t change colors.
Old 06-12-2011, 10:16 AM   #87
1) Replace it.
2) Live with it.
3) Paint it.
what would most people do who are qualified to make a professional, intelligent decision in this case?
Old 06-12-2011, 10:24 AM   #88
If you don‘t like a polka dotted house then “Replace the Siding”.
Old 06-12-2011, 10:27 AM   #89
funny, so eriously painting it with latex and a light color will not do a thing?
Old 06-12-2011, 10:34 AM   #90
I’ll be looking forward to your new thread this winter on...
“what to do about all of the unpainted vertical stripes on my painted vinyl siding”?
Vinyl siding light fixture mount n0c7 Electrical 22 01-18-2013 03:45 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
Storing Vinyl siding in attic? Deform? rebar Building & Construction 2 08-18-2010 10:15 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Vinyl Siding Estimate tmacwith Building & Construction 6 05-01-2007 09:40 PM
