Vinyl Siding, White Spots? - Building & Construction - Page 5 - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 09:08 PM   #61
Tom Struble's Avatar
Rewards Points: 2,002
i was serious not mocking you...as hard as that is right now
Tom Struble is offline   Reply With Quote
Old 05-15-2011, 09:28 PM   #62
Even funnier is your the only one doing it...
dinosaur1 is offline   Reply With Quote
Old 05-16-2011, 09:00 PM   #63
Original siding construction companies' son came by today. He looked at my siding for 20 seconds.....he said its 100% defective.
He never seen this before.
Even better. He personally knows the Mastic rep in our area. He said it wont be a quick process, but it's something he wants to help me with.
Old 05-17-2011, 12:57 PM   #64
Custom Home Builder
Anybody ever see this problem with the Cedarway 8' x 7" panel?
My house looks ridiculous!
thomasjmarino is offline   Reply With Quote
Old 05-18-2011, 06:09 PM   #65
The weird thing is these spots appear only in the back, left and right sides of our home, but not in the front......hail falls everywhere but in the front of our home......can this be partially due to hail damage?
Old 06-08-2011, 08:58 PM   #66
I got a response from PlyGem siding group today.
"Spots" in a horizontal line are usually indicative of fasteners in close proximity to the siding panels. This can cause heat build-up and/or water retention, which can accelerate weathering of these areas. As installation of siding is beyond a manufactures control, this is not covered by warranty.
The Following User Says Thank You to dinosaur1 For This Useful Post:
Tom Struble (06-10-2011)
Old 06-09-2011, 09:55 PM   #67
how old whats the make what type of ins/house wrap
siding247 is offline   Reply With Quote
Old 06-09-2011, 10:00 PM   #68
Home built 1997
Brentwood vinyl siding. Mastic/PlyGem siding
Insurance? Amica
Old 06-09-2011, 10:15 PM   #69
Registered User
Rewards Points: 526
So post #38 was "spot on"........... I'm going out to get a lottery ticket now, LOL.
Thanks for the closing info.
Gary
Old 06-10-2011, 06:11 AM   #70
Gary
this is a new one for me,ive never seen this happen before because of heat build up,but like i said i have seen condensation on the panel where the nails are,i can't imagine the nails getting hot enough under the siding
Old 06-10-2011, 06:16 AM   #71
kwikfishron's Avatar
Rewards Points: 814
So what are they saying, the siding was nailed too loose?
kwikfishron is online now   Reply With Quote
Old 06-10-2011, 06:20 AM   #72
What should my next step be? I obviously cannot keep the siding looking like this.
Old 06-10-2011, 06:30 AM   #73
Rewards Points: 814
I would want to know “specifically” what it was that the installer did to cause this.
Did the rep. remove any panels? Are there any pictures of the nailing?
Old 06-10-2011, 06:33 AM   #74
No rep came out at all. I sent them a sample piece from my home. Can this be painted or should I stay away from that?
Old 06-10-2011, 06:46 AM   #75
Right now I have 2 options. Paint it or try and clean it.
I can always use a light color latex paint, which will flex with the vinyl's movement.
As far as cleaning goes....not sure what I can try to use to remove the spots. I don't think there is anything I can use.
Vinyl siding light fixture mount n0c7 Electrical 22 01-18-2013 03:45 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
Storing Vinyl siding in attic? Deform? rebar Building & Construction 2 08-18-2010 10:15 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Vinyl Siding Estimate tmacwith Building & Construction 6 05-01-2007 09:40 PM
