Vinyl Siding, White Spots? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 02:34 PM   #31
kwikfishron's Avatar
Rewards Points: 92
Originally Posted by dinosaur1 View Post
I am the 2nd homeowner. So does the lifetime warranty the manufacturer gave transfer to any owner?
Lifetime turns into a 50 year prorated warranty for new “owners”.
It’s all there in the link including a toll free number for more info.
I’ll leave reading all the fine print for you.
kwikfishron is online now   Reply With Quote
Old 05-14-2011, 02:37 PM   #32
That's a great thing for me then. 50 yrs prorated. Yeah these are definitely defective. I'm sure they have to send someone out to look at them first.
dinosaur1 is offline   Reply With Quote
Old 05-14-2011, 02:42 PM   #33
oh oh
Copy of Proof of Purchase verifying what products were purchased or installed showing the date of purchase or installation. This can be either a dated product sales receipt, or other proof of purchase. We also require a copy of the property title or deed.
Title or deed isn't a problem, but the 1st one is. I might have to ask the builder for this info, they built it in 1996.
Old 05-14-2011, 02:46 PM   #34
Rewards Points: 92
And let the fun begin.
Old 05-14-2011, 08:03 PM   #35
Tom Struble's Avatar
Rewards Points: 2,002
hmm that is strange,judging from the pics i don't think the nails are the problem,is this localized to the back of the house?is there another house close to this wall? have they changed their windows in the last few years? if they did was it after they did that you noticed the problem?
Tom Struble is offline   Reply With Quote
Old 05-14-2011, 08:34 PM   #36
Rewards Points: 92
Strange indeed, but just for the sake of discussion lets assume all of the answers to your questions are yes. What’s the diagnosis Doc? Enquiring minds want to know.
Old 05-14-2011, 09:52 PM   #37
i know that the regularity in the spotting looks like a nail problem if you look closely you will see there is spotting in the ''dummy'' courses where there are no nails
could possibly be a thermal reflection issue,i don't think it's a factory defect as the spotting wouldn't be all in a line when it's installed on the wall
hard to say though
Old 05-14-2011, 10:11 PM   #38
Registered User
Rewards Points: 4,936
I agree with Tom and the OP, the nails below are causing it. Possible thermal bridging, as mentioned, though I have never seen that before other than ghosting with steel studs inside, pp. 10, 11: http://docs.google.com/viewer?a=v&q=...BiEiG1lHFDd9yA
Are the nails under the vinyl exposed, or covered with a housewrap?
Gary
Old 05-15-2011, 07:55 AM   #39
Gary,i don't think the nails under the siding could ever get hot enough to cause thermal damage,i know the regularity looks like thats the problem but i don't think it's phisicaly possible
press down on the spot,you should be able to feel where the nails are
possible the nails where not driven far enough in
i have seen condensation form on the panel where the nail heads are but thats a different matter
it could also be from water infiltration coming from the weep holes but again they would never line up verticaly when the siding is installed,same thing if it was a factory defect
like i said it's hard to say without being there,but iv'e seen some wacky thermal reflection damage from low e windows before
you need to get a rep to look at this
Old 05-15-2011, 08:48 AM   #40
btw O.P. if you need a ''specific'' answer learn how to ask a ''specific'' question,after 100 post you should know that
Old 05-15-2011, 08:56 AM   #41
no windows were changed recently. The spots appear everywhere but in the front of the home.
Old 05-15-2011, 08:58 AM   #42
Gary
nails are not exposed.
Old 05-15-2011, 08:59 AM   #43
the siding manufacturer rep? they want me to cut a piece of an affected area and mail it to them. not sure what section I would use.
Old 05-15-2011, 01:46 PM   #44
maybe instead of the siding you can send a few pictures
Old 05-15-2011, 02:09 PM   #45
Rewards Points: 5,336
Can you pop off the lower edge and look behind the siding to see if the spot is on the backside?
Ron
Vinyl siding light fixture mount n0c7 Electrical 22 01-18-2013 04:45 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 10:32 PM
Storing Vinyl siding in attic? Deform? rebar Building & Construction 2 08-18-2010 11:15 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Vinyl Siding Estimate tmacwith Building & Construction 6 05-01-2007 10:40 PM
