Vinyl Siding, White Spots? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 07:23 AM   #16
Originally Posted by Ron6519 View Post
Advice doesn't change. Experiment with various cleaners an see what happens.
Start in an inconspicuous place.
It could be the heat from the nail heads has permanently discolored the siding.
Ron
Well...someone asked me to post pics. I don't wanna "test" with any chemicals especially on my home's siding.
dinosaur1 is offline   Reply With Quote
Old 05-14-2011, 08:24 AM   #17
kwikfishron's Avatar
Rewards Points: 996
Dinosaur1, look at this link on how to clean your siding.
http://www.vinylsiding.org/aboutsidi...main/cleaning/
As mentioned it looks like permanent discoloration to me also.
kwikfishron is offline   Reply With Quote
Old 05-14-2011, 08:28 AM   #18
Not worth cleaning then? So 1. I am stuck with it or 2. Replace it....is that correct?
Old 05-14-2011, 08:52 AM   #19
Rewards Points: 996
I would certainly try to clean it but if it is actually faded then our stuck.
You can paint vinyl siding but I’ve never been satisfied with the result.
Old 05-14-2011, 09:00 AM   #20
I would certainly try to clean it but if it actually faded then our stuck.
we have had bad hail storms over the years. insurance covered the cost of my roof 3 yrs ago, but i don't think they would touch this.
Old 05-14-2011, 09:08 AM   #21
Rewards Points: 996
I doubt it would either. If this is fading I’ve got to say I’ve never seen vinyl fade like this before.
Do you know the manufacture of the siding?
Old 05-14-2011, 09:20 AM   #22
Brentwood vinyl siding (silver grey)
Old 05-14-2011, 09:29 AM   #23
Rewards Points: 996
Here’s their site. Read up on their warranty info.
http://www.mastic.com/Products/Sidin...ood%C2%AE.aspx
Old 05-14-2011, 09:34 AM   #24
Rewards Points: 996
Have you tried to clean a spot yet?
Old 05-14-2011, 09:39 AM   #25
seems like lifetime coverage right?
http://www.mastic.com/Support/Warran...arranties.aspx
Old 05-14-2011, 09:46 AM   #26
Rewards Points: 996
It sure does appear to be.
The product is covered for “excessive fading”. I would call this excessive if it's fading.
Old 05-14-2011, 09:49 AM   #27
I wonder if they would replace it all around our home, even in the front where its not fading yet? they would almost have to otherwise the colors wouldn't match.
Old 05-14-2011, 10:03 AM   #28
Rewards Points: 996
I don’t know what they will or will not do. I’d like to know though.
After you’ve tried cleaning and if that does not work, file a claim. You can download the claim packet from the site.
Come back with an update, good luck.
Old 05-14-2011, 10:04 AM   #29
I tried cleaning it many times, so I will definitely file a claim, thanks.
Old 05-14-2011, 01:17 PM   #30
I am the 2nd homeowner. So does the lifetime warranty the manufacturer gave transfer to any owner?
Vinyl siding light fixture mount n0c7 Electrical 22 01-18-2013 03:45 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
Storing Vinyl siding in attic? Deform? rebar Building & Construction 2 08-18-2010 10:15 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Vinyl Siding Estimate tmacwith Building & Construction 6 05-01-2007 09:40 PM
