Vinyl Siding, White Spots? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 09:28 PM   #1
Vinyl siding, white spots?
The back of our home is exposed to some hot sun in the summertime here in WI. I am starting to see more and more white spots (nickel size) show up that are in front of the nailheads beneath the siding. Is there any way to wash the siding or does this have to be repainted? The spots run straight down from top to bottom and they are spaced out between 1 feet of each other. These spots are noticeable on the entire back portion of our home.
dinosaur1 is offline   Reply With Quote
Old 05-11-2011, 09:57 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
try washing with some Fantastick,it's probably just dust that collects on the condensation where the nails are
Tom Struble is offline   Reply With Quote
Old 05-11-2011, 10:16 PM   #3
dust? how do I know for sure?
Old 05-11-2011, 10:20 PM   #4
what if I usea pressure washer w/ all purpose cleaner like Fantastik lightly to clean the siding vs rubbing over 50 ft of vinyl siding?
Old 05-11-2011, 10:30 PM   #5
yea ok however you want
Old 05-11-2011, 10:34 PM   #6
Which means....good or bad idea.
Old 05-12-2011, 08:48 PM   #7
well try it by hand first and see how it goes,if you know how to properly power wash a house do it
Old 05-12-2011, 09:48 PM   #8
what if I take a little bleach and warm water and lightly scrub with a firm brush. Is this something that insurance would possibly cover?
Old 05-12-2011, 11:05 PM   #9
do you have pictures?
Old 05-12-2011, 11:24 PM   #10
Sure I can take some tomorrow evening and post them.
Old 05-13-2011, 08:01 AM   #11
Rewards Points: 5,336
It's doubtful your insurance company will cover washing the house. They wouldn't cover a material issue either.
Try cleaning it with whatever you want and see if it comes off. If it doesn't, you can replace it or live with it. Pressure washing would need to be done very carefully or you'll cut right through the vinyl.
Ron
Old 05-13-2011, 07:46 PM   #12
Ron
wow Ron thanks for the "specific" advice.
Old 05-13-2011, 07:50 PM   #13
Old 05-14-2011, 08:13 AM   #14
Based on these pictures can I get a recommendation?
Old 05-14-2011, 08:20 AM   #15
Advice doesn't change. Experiment with various cleaners an see what happens.
Start in an inconspicuous place.
It could be the heat from the nail heads has permanently discolored the siding.
Ron
Vinyl siding light fixture mount n0c7 Electrical 22 01-18-2013 04:45 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 10:32 PM
Storing Vinyl siding in attic? Deform? rebar Building & Construction 2 08-18-2010 11:15 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Vinyl Siding Estimate tmacwith Building & Construction 6 05-01-2007 10:40 PM
