Vinyl Siding, What Goes Underneath? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 02:56 PM   #31
Lost..
Rewards Points: 336
Originally Posted by tomstruble View Post
you really just need a receiver at the wall,you can nail the other end of the soffit to the fascia board and then cap with aluminum trim
can you provide an illustration of this by chance?
J S Machine is offline   Reply With Quote
Old 01-12-2011, 03:26 PM   #32
Framing Contractor
You can use a 2x4 or 2x6 fascia. The soffit will get nailed to the bottom of the fascia. Up against the wall there will be a F channel nailed to the sheathing. The F is upside down. The two lines of the F is where the end of the soffit slips into.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-12-2011, 03:53 PM   #33
Framing Contractor
Hope this will help.
Joe Carola
Old 01-12-2011, 04:22 PM   #34
Lost..
Rewards Points: 336
I see. I wonder if it is important if I use a 2x for my fascia. I had originally figured and planed for 1x's. My rafters are on 16" centers. here is an example of the area that most concerns me. This little area right here will most likely require some special attention and I'm not sure how to do it.
Old 01-12-2011, 05:16 PM   #35
Tom Struble's Avatar
Rewards Points: 2,002
Vinyl Corner install problem
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
J S Machine (01-12-2011)
Old 01-12-2011, 05:21 PM   #36
Lost..
Rewards Points: 336
Big Thanks folks. I just might be bale to figure some of this out on my own with this help
Any places to purchase vinyl other than the box stores?
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
