Vinyl Siding, What Goes Underneath? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 10:07 AM   #16
KemoSabe
loneframer's Avatar
Originally Posted by J S Machine View Post
Like I said, I like the idea of vinyl siding, I just hope I don't have to buy a bunch of tools to do it. There are other outer layer finishing techniques, but I feel like vinyl siding will be the most cost effective. I'm sure I can figure it out, I just want to do it myself. I don't want to pay anybody to do anything because then I won't have the satisfaction of learning it and doing it. This whole project has been a dream come true, actualy building something myself and having a sense of accomplishment. I'll admit I've been a bit overwhelmed at times, but having great advice and guidance made it easier to do, and I learned how it is done.
I know the worst part of the storm is just ahead, but I am confident I can do it. I'm trying to get a materials list up so that I can get the materials bought.
2 more questions.
I know I will probably use 15w felt on the roof. It will have a regular 3 tab shingle roof, which i still have to learn to do.
On the sides, under the vinyl, I think I will use 30w. Is there any real advantage to using 30w here?
Also, I see loneframer has used staples to attach the felt to his walls before siding. Is this acceptable? What about on the roof? is a staple gun good to attach the felt before shingles go down?
I've been building homes for over 25 years and have never seen anyone use anything but staples for applying felt, or Tyvek for that matter.
Cap staplers have been getting more popular, but I've yet to see one used in this application.
I prefer #30 felt because #15 ain't what it used to be.
Also, there are different grades of felts and building papers.
Over the years, I saw Other types of housewraps come and co, some are still around, but most builders that I do work for have gone back to felt after cronic problems related to other products and installation techniques.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (01-12-2011)
Old 01-12-2011, 10:36 AM   #17
Tom Struble's Avatar
Rewards Points: 2,002
a vinyl siding panel actually is water proof,water problems will usually only manifest itself at the penetrations,there can be some condensation forming on the backside but the very good ''breathabilty'' of un insulated vinyl siding makes it one of the most goofproof cladding out there
for this small outbuilding you don't need any high tech stuff
http://www.vinylsiding.org/installat...nual/index.asp
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
J S Machine (01-12-2011), loneframer (01-12-2011)
Old 01-12-2011, 10:43 AM   #18
Lost..
Rewards Points: 336
Thank you for this information
J S Machine is offline   Reply With Quote
Old 01-12-2011, 10:45 AM   #19
Residential Remodeler
I recently switched to cap staples for installing Tyvek. But that is mainly because it does not get sided immediately, and it is in adherence with Tyvek's installation and warranty. That being said, if it is going to be covered relatively quickly, a slap stapler (hammer tacker) would work just as well.
Just make sure to overlap your seams and if you want to go the extra mile, you could use a seam tape by Dupont for Tyvek. Also, spend some time researching correct ways to flash windows and doors.
Loneframer posted a good picture of window flashing in one of his earlier pics.
CookeCarpentry is offline   Reply With Quote
The Following User Says Thank You to CookeCarpentry For This Useful Post:
Old 01-12-2011, 10:46 AM   #20
KemoSabe
loneframer's Avatar
I agree with Tom. Simple installation procedures will suffice. The intersections at trim details are almost always culprit to water intrusion. Simple flashing details will divert water back to daylight. The problem is, many installers ignore these details for one reason or another.
Old 01-12-2011, 12:06 PM   #21
Lost..
Rewards Points: 336
I'm trying to figure up all the OSB I will need, and I wonder if OSB is acceptable for sofit panels. Do I need to use plywood here or will OSB be work?
Old 01-12-2011, 12:28 PM   #22
Framing Contractor
OSB will not work. If you, you can use 3/8" ac exterior plywood or you can use a 1x6, 8, 10 or 12 depending on your overhang primed pine or 1x azek for the soffit.
My mistake here. You use vinyl soffit. You don't need any wood at all for soffit.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-12-2011, 12:31 PM   #23
Lost..
Rewards Points: 336
I figured OSB might not be the thing of choice. Is there any minimum thickness here for plywood? I have 1' overhangs all the way around.
Old 01-12-2011, 12:32 PM   #24
Framing Contractor
Read my post above you don't need any wood soffit since you're putting vinyl siding on. You will use vinyl soffits.
Joe Carola
Old 01-12-2011, 01:05 PM   #25
Lost..
Rewards Points: 336
Yes I see that, but doesn't the vinyl have to have something to attach to?
Old 01-12-2011, 01:20 PM   #26
You'll use F and J channel. The F channel will go against the sheathing and the J channel attached to the sub-fascia. The soffits will then be put into the J and F channel and snapped together. You can secure the soffit to the cross trusses above every few soffits to secure them in place.
AgentW is offline   Reply With Quote
Old 01-12-2011, 01:24 PM   #27
Lost..
Rewards Points: 336
I see on page 33 of the instructions posted earlier. It doesn't look like there is any backing, as you are suggesting. If this is the case, it will save me from having to frame all the cornice return and all that. So it is just vinyl stretching in between the bottom of the fascia and the actual wall - secured by J and F channels?
This would be great because it will save me money on lumber costs.
Old 01-12-2011, 02:29 PM   #28
Correct, there is no backing. Just vinyl soffits held in place by the J and F channels.
Old 01-12-2011, 02:39 PM   #29
you really just need a receiver at the wall,you can nail the other end of the soffit to the fascia board and then cap with aluminum trim
Old 01-12-2011, 02:49 PM   #30
Very true.. I've just never been a fan of aluminum trim.
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
