Vinyl Siding / Soffit Question - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 08:23 PM   #31
Lost..
Rewards Points: 336
No I do not have help. When I looked into where to get the siding materials, I found a local place. One of the guys they have working there used to install it, and he has been giving me tips and pointers of how to do it.
J S Machine is offline   Reply With Quote
Old 04-14-2011, 08:31 PM   #32
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Ask him about rentals in your area,and see if he has Saturday's off.
Everyone could use a few extra $'s,maybe he'd be willing to help.
oldfrt is offline   Reply With Quote
Old 04-17-2011, 08:35 PM   #33
Lost..
Rewards Points: 336
I think I may have done these outside corner posts wrong. If you look at this picture, you can see where I cut the post off even with the bottom of the soffit.
I think I should have run this right side of the post all the way up to the gable soffit, and notched it out for the front. I know I can add a half piece of corner to this gable end wall and lengthen it up to the gable soffit, but I feel like that wont look right.
Will this work or should I have notched it like I was explaining?
Old 04-17-2011, 09:25 PM   #34
Yes you should have notched it, but unless you want to buy another corner you'll have to patch it in somehow. Have you done any other corners or is this the first?
Brian42 is offline   Reply With Quote
Old 04-17-2011, 09:28 PM   #35
Or you could do like the picture in post 26 I've never seen that done that way before but it looks like a very workable thing to do that may still work!
Old 04-17-2011, 09:29 PM   #36
Lost..
Rewards Points: 336
I've already cut them all. Oh well .
I think all four of the corners were around $50. I may just pick up some more of them. I really hate to patch them.
Old 04-17-2011, 10:32 PM   #37
oldfrt's Avatar
Rewards Points: 186
Your corners will work alright.
Just extend the last piece of soffit over it and have the return
bent to meet it.
We do it all the time,even without the framed box there.
I'll see if I can draw up some pics of what I'm trying to explain.
Old 04-17-2011, 11:34 PM   #38
Registered User
Rewards Points: 526
Sorry to interrupt. Did anyone mention the window flashing is wrong?
Gary
Old 04-17-2011, 11:48 PM   #39
oldfrt's Avatar
Rewards Points: 186
Here you go,
A good brake guy could do this or something similar to address that area.
vinyl Siding / Soffit Question-untitleda.jpg   vinyl Siding / Soffit Question-untitledcccc.jpg   vinyl Siding / Soffit Question-untitledbbbbbb.jpg
Old 04-18-2011, 05:42 AM   #40
Lost..
Rewards Points: 336
Gary
How so?
Can you please elaborate? I know the bottom strip of flashing should be under the window flange instead of over. Is this what you are talking about?
Old 04-18-2011, 05:47 AM   #41
Lost..
Rewards Points: 336
Originally Posted by oldfrt View Post
Here you go,
This is what Brian42 is talking about, as illustrated in post 26. That could work. I am still looking at what to do.
Old 04-18-2011, 07:54 PM   #42
Tom Struble's Avatar
Rewards Points: 2,002
Depending on how confident you are in using a brake,the rental cost,the aggravation of transporting it,the
possibility of wasting material,and a maybe a less than desirable result,I might be inclined to just hire out
this part of the job.
Didn't you say somewhere that you had help that use to install?
you do the nicest brake work oldfrt
Tom Struble is offline   Reply With Quote
Old 04-18-2011, 10:11 PM   #43
Registered User
Rewards Points: 526
Yes, the bottom too. http://www.mtcc1170.com/images/BCRainScreen.pdf
Gary
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
New Vinyl Siding Went From $43k to $15k In A Few Days nycgto Off Topic 12 07-26-2010 11:46 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
