Vinyl Siding Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 12:56 PM   #1
the Musigician
DangerMouse's Avatar
vinyl siding question
hi guys!
how close to the ground can vinyl siding be installed? can it touch concrete at ground level?
tnkx!
DM
Old 08-12-2008, 07:23 PM   #2
Registered User
Termite's Avatar
The code requires a minimum of 6" from grade to siding. Grade is not necessarily dirt...Grade is defined as whatever is against the house. So, if your patio or driveway abuts your house, it is grade. The siding should be 6" away from it.
This code is intended to reduce rot from water splashback, but also to discourage termites and make their paths of entry easier to locate. So, the 6" requirement is there whether it is vinyl, stucco, or wood.
Old 08-13-2008, 07:08 AM   #3
the Musigician
thank you kctermite! now i just need to figure out what to PUT in that 6" to maybe 12" space.... it is concrete 2 to 3 feet from the walls all around the perimeter, so whatever i put on it will touch concrete only. i need cheap but strong/safe/easy to install.... any suggestions or pics of what others have done with a 'polebarn' style home with crawlspace would be a big help. tnkx again!
DM
Old 08-17-2008, 05:53 PM   #4
What is put in that 6 inch section between the grade and the start of the siding?
de_sjiem is offline   Reply With Quote
Old 08-18-2008, 11:48 AM   #5
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
The guys that did my siding installed color matched aluminum coil stock.
comp1911 is offline   Reply With Quote
Old 08-26-2008, 06:55 PM   #6
the Musigician
THANK you guys! that was what i needed to know! coil stock i can do! it WILL pass code, yes?
PS I'M BAAAAACK!! hehehehe
DM
Old 08-26-2008, 06:59 PM   #7
Registered User
Termite's Avatar
I see no reason that wouldn't pass an inspection.
Old 08-26-2008, 07:41 PM   #8
the Musigician
tnkx kc, good to see you again. =o)
DM
Old 08-26-2008, 09:51 PM   #9
Registered User
Termite's Avatar
Yeah, I was starting to think that house drove you crazy and they had you locked safely away in an asylum! Post some pics for us once that siding's up.
Old 08-27-2008, 05:25 AM   #10
What about the bugs now?
stuccoman is offline   Reply With Quote
Old 08-27-2008, 06:14 AM   #11
the Musigician
bugs?
DM
Old 08-27-2008, 06:20 AM   #12
Old 08-27-2008, 06:34 AM   #13
the Musigician
you lost me.....
DM
Old 08-27-2008, 06:36 AM   #14
The termites/bugs can go behind the flashing just like any other cladding.
Old 08-27-2008, 06:57 AM   #15
the Musigician
oic.... behind the coil is/will be foundation grade 3/4" bugtreated ply as per code.
DM
Vinyl Siding Question! handy man88 Building & Construction 6 08-30-2007 11:21 AM
Vinyl siding question? kcrossley2 Building & Construction 5 12-18-2006 05:20 AM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
