Vinyl Siding Question - Building & Construction - Page 5 - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 03:03 PM   #61
Old School
Willie T's Avatar
Originally Posted by markharmon View Post
Shouldn't the lookout ends lets say 2x4's be flush with a 2x4 ledger?
Ideally, yes. But since you have to have the bottom edges of the lookouts where they MUST be (level) in order for them to be in the correct position to mount the soffit, that interior bottom edge corner needs to be angle cut off the end of the lookout so as not to push into the siding. Don't worry, you'll still have a couple of inches to nail to at the top.
If you feel the need for more nailing area, use 2x6's... all you are looking for is to have that bottom edge at the height it needs to be.
Willie T
Old 05-06-2013, 03:06 PM   #62
Old School
Willie T's Avatar
So basically the notch in the lookouts on the wall ends are to create a space for the siding, right? then in front of the siding you attach your j channel to the lookouts to but the soffit up against the siding?
Yepper.
Willie T
Old 05-06-2013, 03:08 PM   #63
Old School
Willie T's Avatar
Here is another thing my gable rake wall has no overhang. How do I get a flush fascia so the siding goes under it?
Could you make a drawing of what you want to achieve?
Willie T
Old 05-06-2013, 05:20 PM   #64
I dont have one. It is just an end gable wall with no soffit so basically the fascia will be flush with the siding.
markharmon is offline   Reply With Quote
Steel Siding vs Vinyl Siding ?after? Painting 4 04-24-2013 07:22 PM
Vinyl siding over lap siding thunderhead Carpentry 5 06-08-2011 10:56 PM
osb vinyl siding question jjjeno Building & Construction 2 04-16-2011 08:01 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
