Vinyl Siding Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 07:53 PM   #1
Vinyl siding question
Hi,
I keep getting different answers on this topic. Do you install soffits and j channel before or after siding?
markharmon is offline   Reply With Quote
Old 05-01-2013, 08:19 PM   #2
firehawkmph's Avatar
Rewards Points: 1,868
Mark,
siding usually runs right up to the underside of the soffit. Siding ends in a piece of finish trim, which is nailed up like J channel. When I am siding a house or garage, I usually run the siding up to the point where the next row will be the last. Then I install the soffit. Once the soffit is up, then I finish the last row of siding. You can put up the soffit first, that won't hurt anything. But when doing a building that has to have some kind of scaffolding set up, you wouldn't want to set up the scaffold just to do the soffits, then tear the scaffold down to start on the siding, then put it back up to finish the siding. Basically you are starting from the bottom and working your way to the top. If you are asking about your shed, you should be able to reach everything off a small stepladder, so it won't matter.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-01-2013, 09:14 PM   #3
Originally Posted by firehawkmph View Post
Mark,
Mike Hawkins
The reason I ask is because if you put up your soffit and J channel before siding that area then you add a piece of j channel up against the soffit j channel would there a potential for water to get in between the 2 j channels?
Old 05-01-2013, 09:21 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,118
it depends on how the final course of siding lands.. if its a larger panel you can run it up past and then install the fchannel for the soffit.. if you end up with a small piece of siding then just tuck it up into j channel that butts to the soffit
vinyl siding gets water behind it more than any other type so i wouldnt worry about it much if you have properly sealed the water.. the biggest misconception with people is that they think the siding is what keeps the water out.. wrong.. make the house water tight first in the prep stage and then the siding is just lipstick on a pig
woodworkbykirk is offline   Reply With Quote
Old 05-02-2013, 06:44 AM   #5
kwikfishron's Avatar
Rewards Points: 420
You just need to make sure that the house wrap runs continuously up the wall and beyond the soffit J so that any water that may get in there has a way to escape down the face of the house wrap and not the sheathing.
You'd be surprised on how much rot I've repaired because the house wrap was cut off at the soffit and did not run up behind it.
kwikfishron is online now   Reply With Quote
Old 05-02-2013, 10:38 AM   #6
Old School
Willie T's Avatar
Ron is right. And, truthfully, all of the wall... sheathing, insulation, wraping, brick... whatever...... should be built first, and run up at least 6" past where the soffet will meet the wall. (There IS a bit of a difference if you are stuccoing...)
Nothing looks tackier (and invites infiltration) more than than two "J" chanels meeting up there at right angles. Looks like an after-thought.
This is usually only done by after-market people installing siding "cover-up" over something else.
Willie T
Old 05-02-2013, 01:07 PM   #7
So lets say I'm vinyl siding a house. Your saying I should install it up the where the soffit meets the wall then tack a j channel over top of the vinyl siding then install the soffit panels?
Old 05-02-2013, 02:06 PM   #8
Old School
Willie T's Avatar
This is what I'm talking about.....
No matter WHERE the soffit hits the vinyl, in the thin top part, or in the fatter lower section, the single "J" channel fastened to the soffit framing outlookers ( the one that supports the soffit) is the ONLY edge you will ever see... NOT a bulky, double, 90 degree pair of butting "J" chanels.
And this will even work, to large extent, if the vinyl siding is running uphill, out of level a little bit.
One, clean, square "J" channel....... nothing else. It really looks sharp...... AND deliberately planned.
Vinyl siding question-soffit-1.jpg   Vinyl siding question-soffit-2.jpg   Vinyl siding question-soffit-3.jpg
Willie T
Old 05-02-2013, 02:39 PM   #9
How are you getting that J channel behind the rafter though?
Old 05-02-2013, 02:42 PM   #10
When you put in your soffit lookouts you add your ledger board nailed to the building level with the very bottom of the fascia board or actually a little higher to account for the channel depth?
Old 05-02-2013, 02:48 PM   #11
Old School
Willie T's Avatar
Yes, a little higher. You do not want to distort the shape of the siding. That's why you never fasten a "J" channel (or an "F" channel) to the siding, if you can help it... It crushes and bends the shape of the siding if you do not use screws, and only draw it down a tiny bit. And it will also prohibit the inevitable necessary movement of the vinyl due to expansion and contraction. Not cool at all... It will cause the vinyl to buckle, in a new york minute!
Of course, you would not waste a piece of siding just to run it way up above where the soffit will hit. A few inches is fine.
Willie T
Old 05-02-2013, 02:50 PM   #12
Old School
Willie T's Avatar
????? The "J" channel doesn't touch a rafter anywhere.
Willie T
Old 05-02-2013, 02:53 PM   #13
Old School
Willie T's Avatar
Notice that the outlooker has the interior bottom corner cut off at the siding angle? That's why the ledger (if you even use one..... Some guys don't.) can easily be an inch or two higher than the soffit.
This drawing is EXAGERATED , to give you a clearer idea.
Willie T
Old 05-02-2013, 03:33 PM   #14
the blue siding in the picture what is the top of the siding attached to?
Old 05-02-2013, 03:35 PM   #15
That piece of wood in the picture is a lookout?
Steel Siding vs Vinyl Siding ?after? Painting 4 04-24-2013 07:22 PM
Vinyl siding over lap siding thunderhead Carpentry 5 06-08-2011 10:56 PM
osb vinyl siding question jjjeno Building & Construction 2 04-16-2011 08:01 PM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
