Vinyl Siding Over PT Plywood - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 07:04 AM   #16
PPBART's Avatar
Rewards Points: 305
Originally Posted by Joe Carola View Post
Why did you use pt?
This has been one of those projects with lots of changes along the way (as my wife thinks of something different). Since it's essentially open to the weather (very wet very often down here) everything in the structure below top plate is PT (YellaWood). I sheathed the lower 3.5' of the 9' stud walls with the plywood; upper portion will be covered with screen. The original plan was to just paint the plywood walls, then wife decided we should cover it with vinyl siding "to reduce the amount of painting she will have to do."
I pointed out the trivial amount of painting avoided vs the cost of siding -- to no avail.
Here's a pic I took this morning... Getting anxious to finish this thing!
PPBART is offline   Reply With Quote
Old 07-21-2012, 01:43 AM   #17
Registered User
Rewards Points: 5,238
Treat it as a house.... WRB (water resistive barrier) required. Vinyl will leak water, without a WRB- the wetting/drying cycles will out-gas the p.t. chemicals more/faster. A felt paper will hold/store the water next to the ply, drying inward, wetting the wood framing for mold/rot. Rosin paper (leaks/stains red dye when wet) is not recommended personally, use a plastic housewrap like Tyvek (58 perms) to keep the wood dryer.
Gary
Gary in WA is online now   Reply With Quote
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 10:02 PM
Vinyl siding over lap siding thunderhead Carpentry 5 06-08-2011 11:56 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
