Vinyl Siding Over PT Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 03:21 PM   #1
PPBART's Avatar
Rewards Points: 323
I plan to cover the lower 3.5' of outside walls on a grill-house with vinyl siding (upper portion is screened). The walls are already sheathed with 1/2" pressure-treated plywood. Do I need to apply felt paper or other wrapping? I really don't see any benefit, but I've been told that I should.
PPBART is offline   Reply With Quote
Old 07-17-2012, 05:38 PM   #2
kwikfishron's Avatar
Rewards Points: 576
Felt's cheap, keep the water off the ply, treated or not, unless it's actually marine grade plywood.
Even then "I'd" still paper it.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
mae-ling (07-17-2012), Tom Struble (07-17-2012)
Old 07-17-2012, 08:09 PM   #3
Davejss's Avatar
Rewards Points: 764
It probably won't help and deffinately won't hurt. 15 lb felt or red rosin paper would be cheap enough.
Davejss is online now   Reply With Quote
Old 07-17-2012, 08:13 PM   #4
Rewards Points: 13,694
Your going to have to use stainless steel roofing nails to install it.
Galvinized will just corrode off.
Old 07-17-2012, 09:00 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
Joe,that was an issue with ACQ,
MCQ [which has replaced it for most residential use]doesn't have the same issue
Tom Struble is offline   Reply With Quote
Old 07-17-2012, 09:05 PM   #6
For the cost of a small box of nails is it worth guessing which one it is and having to do it over?
Old 07-17-2012, 11:38 PM   #7
good point
Old 07-17-2012, 11:38 PM   #8
Rewards Points: 2,212
Originally Posted by PPBART View Post
grill-house
Never heard this term before. Definition?
mae-ling is offline   Reply With Quote
Old 07-18-2012, 08:18 AM   #9
PPBART's Avatar
Rewards Points: 323
My "grill house" is just a 10'x14' building where we have a couple of grills, a small refrigerator, sink for cleanup and some counter space. I guess it could be called an "outdoor kitchen" but IMO that implies something a bit more elaborate. We used to have the grills et al under a roofed (but otherwise open) patio but I got really tired of cleaning bird poop off everything, so that's why this structure has screen walls.
The Following User Says Thank You to PPBART For This Useful Post:
mae-ling (07-18-2012)
Old 07-18-2012, 08:36 AM   #10
PPBART's Avatar
Rewards Points: 323
Stainless steel and copper fasteners are both virtually immune to corrosion, but get pricey pretty quick. However, it's only a pound or two of siding nails, so price really isn't a problem.
As for galvanized nails, I learned that plain old galvanized fasteners simply aren't designed for the increased level of corrosion, and could fail in a very short time. However, "hot-dipped galvanized" nails with a "G-185" designation (which refers to the thickness of the galvanization) on the package is supposedly OK for use with ACQ lumber.
But with all that said, I've got PT wood that's been in place for over 20 years, installed with galvanized nails (which may or may not have had that G-185 designation), and never (yet) noticed any corrosion problems. However, for this siding job I will probably use SS -- and I guess I will pick up a roll of felt today.
kwikfishron (07-18-2012)
Old 07-18-2012, 10:16 AM   #11
Rewards Points: 576
Hot dipped galvanized will work just fine.
Old 07-18-2012, 11:11 AM   #12
MarginallyQualified
Rewards Points: 2,464
My "grill house" is just a 10'x14' building...
for the cost of less than 12 sheets of CDX ... I'd pull that PT plywood off.
Tyvek? sure. Vinyl? why not. I'd still prefer Hardie though.
Old 07-18-2012, 02:22 PM   #13
PPBART's Avatar
Rewards Points: 323
Originally Posted by TarheelTerp View Post
for the cost of less than 12 sheets of CDX ... I'd pull that PT plywood off...
It's actually only six sheets -- but considering the trivial cost of the proper nails there's no way I would pull the PT off just to replace it with CDX(!)
Old 07-18-2012, 03:36 PM   #14
MarginallyQualified
My concern is encapsulating (even old) PT lumber.
Maybe I've read too many threads by the safety weenies?
Old 07-18-2012, 04:43 PM   #15
Framing Contractor
Why did you use pt?
Joe Carola
Joe Carola is offline   Reply With Quote
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 09:02 PM
Vinyl siding over lap siding thunderhead Carpentry 5 06-08-2011 10:56 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
