Vinyl Siding Over Old Wood Shake?? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 08:50 AM   #16
Professtional Remodeler
Hi ttam,
You can install the vinyl siding over the shake if (and this is a big if,) the butt (bottom) of the shake is no thicker than 1/2". If the butt of the shake is larger it needs to come off. If you go over the shake you will need to use a flat 1/2" to 3/4" polystyrene backer board. However when doing this you will need to build out all you windows, doors and fascias. By ripping the shake off, you should be able to away without doing the build out. Ripping off the shake will provide a much flatter and better looking job if installed properly. You should never install vinyl siding over existing wood shakes directly. It voids the manufactures warranty and it is almost always looks bumpy.
valueremodeling is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
molding under vinyl siding aharbin Carpentry 5 05-14-2009 10:19 PM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 08:48 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
