Old 09-16-2010, 09:18 AM   #1
Vinyl siding over old 12" lapboard siding
I have an old garage with peeling & rotting 12" lapboard siding. Can I install the new vinyl siding directly over the lapboaed siding after I wrap the building in Tivex & replace the rotting lapboard peices? There is room on all the window & door trim (3" wide) to install the "J chanel" as to hold the vinyl inplace. The old lapboard siding is only a 1/4" thick. I just don't want the vinyl siding to look wavey vertically.
thanks
Mike
Michael1960 is offline   Reply With Quote
Old 09-16-2010, 10:32 PM   #2
Tom Struble's Avatar
what the quot are you talking about?but no you have to install an underlayment to flatten the wall
Tom Struble is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
