Vinyl Siding Over Aluminum Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 07:14 PM   #1
vinyl siding over aluminum siding
Hi. I have been looking at some mobile homes in a real nice country park. I can across a few I really liked, but one seems odd to me...they had their vinyl sidings installed on top of the old aluminum siding. The maintenance man for the park did it in his spare time. Why in the world would someone install vinyl over aluminum (besides laziness)? Is there some kind of benefit I am unaware of? Also, seems to me this would not be a good idea...am I right? Please help me understand :-) Thanks
abbydaisy08 is offline   Reply With Quote
Old 10-30-2010, 08:41 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
your right its not a recomended procedure
Tom Struble is offline   Reply With Quote
Old 10-30-2010, 09:47 PM   #3
Rewards Points: 5,336
Stupidity? Lack of knowledge in the transition? Could be that the siding is part of the structure.
Ron
Old 10-30-2010, 11:03 PM   #4
jlhaslip's Avatar
Rewards Points: 2,726
Ron
I agree on the first two...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-31-2010, 05:56 PM   #5
does anyone know why its not recomended,when its ok for other siding types?
Old 10-31-2010, 06:13 PM   #6
kwikfishron's Avatar
Rewards Points: 772
Because as previously mentioned the aluminum is also the sheathing on most mobiles and not a suitable nailing surface for anything.
kwikfishron is online now   Reply With Quote
Old 11-01-2010, 09:14 PM   #7
yea but besides that,these sidings have internal drainage systems,that are disrupted when nails are driven thru it,which can actually cause water to become trapped in the underlaying siding
Old 11-02-2010, 05:28 AM   #8
Rewards Points: 772
Driving a nail through the aluminum will make a weep hole not weep, or water not to drain out of the bottom of the panel?
Old 11-02-2010, 11:27 PM   #9
point is your disrupting the built in drainage system of the underlaying siding,you don't know what your doing when you drive nails thru it
installing vinyl siding over aluminum siding brad7359 Remodeling 8 07-24-2010 06:28 AM
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 10:55 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
