Vinyl Siding Issue - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 07:05 PM   #16
Originally Posted by woodworkbykirk View Post
i think he means to have the azec to act as something that will cover both the wall sheathing and the joint in the foundation.. then the drip edge or flashing sits on that.. its a common detail and gives a bit of a shadow line.. as long as the azec is set into a bead of caulking , shouldnt be any issue
there is no sheathing. It is old style 2x4s with 1 by 4 cross bracing. The roofing felt underneath is in bad shape. Its been up there for for years so falling apart. After putting on a drip edge would you just nail up your starter strip on top of the lip of the drip edge?
mikem201 is offline   Reply With Quote
Old 02-13-2013, 07:55 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
something like that.. or run a piece of coil stock along the bottom of the studs and use tech screws to attach the starter
woodworkbykirk is offline   Reply With Quote
Old 02-15-2013, 07:03 AM   #18
Rewards Points: 150
That is exactly what I meant thank u
kaschmid3 is offline   Reply With Quote
Insurance claim for vinyl siding thru-hiker Off Topic 3 12-02-2010 03:29 PM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 11:28 AM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
