Vinyl Siding Issue - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 06:12 PM   #1
Vinyl siding issue
My garage is about 50 yrs old and has no sheathing just 1 by 4 cross bracing with roofing felt attached which is really deteriorating. The previous owner put up vinyl siding over wood siding which to me was not smart. Lately I have noticed some water getting under the vinyl past the wood siding and through the felt. I plan to remove the vinyl and wood siding from that area and put up sheathing with house wrap and put the vinyl back up. Do you think a drip edge type of flashing is smart under the bottom course of vinyl siding?
mikem201 is offline   Reply With Quote
Old 02-11-2013, 06:45 PM   #2
Rewards Points: 13,228
Got to have a picture.
Siding over old wooden siding is done all the time with no issues.
Only place I can see it leaking is if the slab was pored to low and it's coming in under the wall.
Old 02-11-2013, 07:41 PM   #3
Yes slab was poured too low and the wall foundation was not brought up high enough. I can see some drips about halfway up the wall from behind the felt and yes there is some water getting in under the wall. Should I seal the wall issue on the outside with sealant or a flashing? As far as the drips from above what do you think about my suggestion from the previous post?
Old 02-11-2013, 09:25 PM   #4
Got to have that picture.
Old 02-12-2013, 09:08 AM   #5
why do you need a picture when I am explaining this to you?
Old 02-12-2013, 09:22 AM   #6
Not sure how anyone here can tell you why a sided wall can leak in the middle, the best way to keep the bottom from leaking, what measures to take to prevent future damage without seeing it.
All you will end up with is a bunch of guesses and more questions without a picture.
Old 02-12-2013, 09:57 AM   #7
Just give me your opinion. I don't own a camera.
Old 02-12-2013, 04:04 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
he cant give an opinion without seeing whats going on.. it can be like a doctor diagnosing a severed limb over the phone
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
joecaption (02-12-2013)
Old 02-12-2013, 06:45 PM   #9
Rewards Points: 150
Any pics hard to envision. Is there an overhang, exposed rafter tails. Old school roofing and siding used to be put up that way with bridging ( or 1x4) for cedar shakes do there was somewhere to nail
kaschmid3 is offline   Reply With Quote
Old 02-12-2013, 07:06 PM   #10
No drip cap is not going to keep out water!
woodworkbykirk (02-12-2013)
Old 02-12-2013, 07:15 PM   #11
Registered User
Rewards Points: 5,180
Another exact thread was merged with this one, please keep only this thread active. Members will find it when checking "New posts", thank you, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 02-12-2013, 07:40 PM   #12
Yes there is an overhang of about 6 inches or so, not much. What do you think of my suggestion in regards to fixing the issue? Also, do you suggest a drip edge under the bottom course of vinyl siding so water does not get under the wall and into the garage?
Old 02-13-2013, 06:28 AM   #13
Rewards Points: 150
Yes for the bottom try putting apiece of 1/4 in azek (or similar material) so that it goes past the slab and also past the vinyl(prefererably under tar paper too) then put the tac strip for siding back where it was mow on that piece of azek. For the top use piece of 5/4 azek(or similar material) butg it up to top most point of wall int roof with the bottom inside corner dadoed so the siding goes under it. Hope u can understand and I hope it helps
Old 02-13-2013, 08:43 AM   #14
azek is not flashing though. I meant like a drip edge under the bottom course of siding?
Old 02-13-2013, 04:02 PM   #15
i think he means to have the azec to act as something that will cover both the wall sheathing and the joint in the foundation.. then the drip edge or flashing sits on that.. its a common detail and gives a bit of a shadow line.. as long as the azec is set into a bead of caulking , shouldnt be any issue
Insurance claim for vinyl siding thru-hiker Off Topic 3 12-02-2010 03:29 PM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 11:28 AM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
