Vinyl Siding Installation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 07:28 AM   #1
Rewards Points: 156
Vinyl siding installation question
I am getting a bit ahead of myself with this question, since I have a few things to do before installing siding, but I like planning for the future.
How important is it that the area that vinyl siding is being installed on is flush?
Basically, I am working with an area where the bottom 3 feet of the area is bumped out about 1/2" to 5/8" more than the rest of the area that siding will be applied to. I was wondering if this is a big deal or if I can just make it work.
Branden is offline   Reply With Quote
Old 06-01-2010, 12:10 PM   #2
kwikfishron's Avatar
Rewards Points: 788
That depends if you want to see a bump in your wall or not.
You could add 1/2" insulation to top side only to make it go away.
kwikfishron is online now   Reply With Quote
Old 06-01-2010, 12:17 PM   #3
Rewards Points: 156
I really don't mind a bump in the area. It is in the back above the garage on such a small area. I am worried that if I add that insulation, I will have trouble with the J Channel on the one side. It meets a brick corner and I don't want the siding to come out too far past it.
Installing Vinyl Siding ptarmigan61 Roofing/Siding 15 07-09-2015 03:02 PM
Covering large hole in vinyl siding eastie Building & Construction 4 04-01-2010 08:43 AM
Question about vinyl siding bulging and forming bubbles sljacobs Building & Construction 6 03-08-2010 07:17 PM
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 10:55 AM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
