Vinyl Siding Installation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 07:17 PM   #1
Solutions (handyman)
Rewards Points: 362
Vinyl siding installation question
Should the siding be butted tight to the corners and J-trim around windows & doors or should there be a 1/4" or more gap? This is assuming there are more than one board per course, allowing for expansion and contraction.
I ask because I have had two opinions ... today. Also consider that I am in a cool (cold) climate and am installing around the freezing temperature.
Advise always welcome.
Regards, Mark
Mark Harvey is offline   Reply With Quote
Old 01-03-2012, 07:41 PM   #2
Rewards Points: 2,238
Leave a gap between the siding panels into the corner-posts, and the "J"
channel - 1/4 inch gap.
It's cold - store the siding in a cold area (garage) - not a heated area -
for awhile (1 or 2 weeks) before you're going to install it.
"Acclimation".
Store it flat.
Watch you're nailing.
New construction - remodel??
rossfingal
More to follow.
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Tom Struble (01-03-2012)
Old 01-03-2012, 10:06 PM   #3
Rewards Points: 2,202
Amount of Gap depends on the make and temperature at which it is being installed. The manufacturer website should have instructions.
mae-ling is offline   Reply With Quote
Old 01-04-2012, 10:09 AM   #4
Rewards Points: 362
Siding gap
Rossfingal, New construction. Thanks for the advice.
Old 01-04-2012, 10:22 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
vinyl doesnt really need much acclamitization time, it will adapt pretty quicky as its a very thin product..
regarding installing in the cold, your best bet is to gap is more now that its fully contracted, it will only expand as it warms up. i typically keep the siding back 1/4 - 3/8 from corners and inside of j channel or j'd out windows and doors this time of year. in the summer you can install it tighter to allow for contraction come wintertime
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
rossfingal (01-05-2012)
caulking vinyl siding? bergerdude Building & Construction 1 03-26-2011 07:21 AM
Question about vinyl siding bulging and forming bubbles sljacobs Building & Construction 6 03-08-2010 08:17 PM
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 11:55 AM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
