Vinyl Siding Expansion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 09:04 PM   #1
Rewards Points: 201
Vinyl siding expansion
I am using Royal Woodland vinyl siding. It is a 46 mil, 16' 4" long.
On their website, under the physical property of coefficient of linear expansion, it states:
Standard Method: ASTM E-831
Unit of Measure: 105 in/in/°F
Result: 3.07
Can someone interpret that for me ?
What I would like to know is how much a full length panel (16' 4") would expand in length going from 0 degrees to 100 degrees.
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 11-06-2011, 09:21 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
cant say for a 16' piece as all ive ever worked with is 12' lengths. if im installing vinyl in the winter i use the nailing flange as a gauge as to how much space to give it... first peice goes on then the peice next to it... in cold temperatures i will leave about a 1" space between the ends of the nailing flanges so when the summer comes it can expand... then if installing in the summer on a really hot day i will install them closer together to allow for it to shrink and still cover in the winter...
this might be kinda of tricky to understand without showing pictures of exacty what im describing... i am installing a large amount of siding right now unfortunately its not vinyl so i cant take any photos to clarify my methods
woodworkbykirk is offline   Reply With Quote
Old 11-07-2011, 06:54 AM   #3
Length is usually not an issue, since the manufacturer has designed overlaps into the material. I would be more concerned about vertical expansion, depending on when the siding is installed.
Old 11-07-2011, 10:06 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
http://www.royalbuildingproducts.com/contactus.aspx
ask them
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
woodworkbykirk (11-07-2011)
Old 11-07-2011, 03:54 PM   #5
nice work tom, royal makes some decent siding. definitely my preference for brands
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
