Vinyl Siding / Electrical Service Entry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 04:19 PM   #1
Vinyl siding / electrical service entry
How does one go about moving the electrical mast and meter for vinyl siding installation? I am assuming hire an electrician ? If that is the case can they somehow reposition it out of the way temporarily yet still be connected? Any suggestions / tips are appreciated.
SAGENT is offline   Reply With Quote
Old 04-28-2009, 07:21 PM   #2
Rewards Points: 5,336
If you hire a competant electrician, you shouldn't have to give him guidance.
This is not a DIY project for a majority of people. But that sounds like a question someone would ask who was contemplating it.
Ron
Old 04-28-2009, 08:16 PM   #3
Registered User
Rewards Points: 5,212
Instead of removing, can you install a piece of 5/4x4, ripped, and shoved tight to the pipe? I chamfered inside edges on both pieces with a router, painted all sides, installed. Use J-trim next to. Be safe, G
Old 06-04-2009, 07:31 AM   #4
Yes the electrician should defiantly not need guidance and should already know where to move it when assessing your situation. i would not attempt it if i was you. always best to be safe than sorry
Service Repair - 24 Hour Repair Maintenance Services
aquaman is offline   Reply With Quote
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
