Vinyl Siding Around Existing Furnace Exhaust Pipe - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 05:40 PM   #1
Vinyl siding around existing furnace exhaust pipe
I'm installing vinyl siding on my old construction home. Everything is going just fine, except I'm a little baffled by what to do with these exhaust pipes for the furnace. I'm thinking the best thing to do is to just get J blocks, but is there something better to do?
ikessky is offline   Reply With Quote
Old 10-19-2012, 06:23 PM   #2
Rewards Points: 2,238
You can work around them by putting laps in the siding.
It's a little more money and time to use some type of "J" Blocks.
Using "J" Blocks does look better - in my and other peoples opinion.
It can be done either way.
rossfingal
Just remembered -
Another option is to cut the PVC vent pipes - drill holes in the new siding - install the siding and use PVC
connectors.
rossfingal is offline   Reply With Quote
Old 10-19-2012, 06:38 PM   #3
Rewards Points: 12,868
The best way is with split siding block.
The piece that mounts to the wall is made in two pieces or has a split at the top.
If the hole is to small just set the block on a piece of wood and use a hole saw to make it bigger. The piece of wood will hold the pilot drill in places.
http://www.simsupply.com/p-8738-almo...s-j-block.aspx
Lowes and Home Depot stock them.
mae-ling (10-19-2012)
Old 10-19-2012, 09:16 PM   #4
J-Blocks it is. I already have to lap the siding for the natural gas connection and I did it for the spigot on the front of the house. I'm not a real fan. I also do not want to cut the pipe inside since it is heating season and I live 30 minutes from the closest hardware store. My luck is that they would be closed and I wouldn't have enough parts on hand to get it back together before the temp got too low in the house.
Old 10-20-2012, 10:28 AM   #5
I would also use one around the outside faucets, and the phone, and cable boxes and the outside disconnect.
The siding has to be able to expand and contract.
You want to shim them so there sitting level where those laps are.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
heat vents for vinyl siding skychief Building & Construction 3 06-11-2010 09:37 PM
how to install vinyl of existing siding jgreen2121 Remodeling 8 03-11-2010 03:55 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
