VINYL SIDING & WET BASEMENT - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 10:51 AM   #1
We replaced of vinyl siding 2 years ago. Builder extended siding down to ground. We are now having problems with water in basement after hard rain. Any connection?
scwynar is offline   Reply With Quote
Old 06-08-2012, 12:50 PM   #2
kwikfishron's Avatar
Rewards Points: 90
Maybe, maybe not.
Posting some pictures (inside and out) would be a good start.
How to attach a photo to a post
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mae-ling (06-08-2012)
Old 06-08-2012, 05:21 PM   #3
Siding should not have anything to do with this.
Only possibilities is starer strip nailed to close to grade and water backs up under siding starting strip and into block wall. only other thing if a 'J" channel at a window was folded incorrectly and that can channel water back i nto the sheeting/tarpapr/celotex and down the wall between the siding and to top foundation plate. That can be tested with a heavy sprinkler for some time to re act in the basement.
Other then that were there any grade changes if so that could be a catalyst .
21boat is offline   Reply With Quote
Old 06-08-2012, 05:51 PM   #4
Rewards Points: 90
There's all kinds of ways water can get behind vinyl siding and end up in the basement.
Here's just one example from the other day. Basement problem... but is it really the roof!?
To say that "this" or "that" are the only ways water can get behind the siding and into the basement is just wrong. The true list of possibilities is a long one.
Based on the lack of info supplied by OP it may have nothing to do with the siding at all.
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
mae-ling (06-08-2012), Tom Struble (06-08-2012)
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 08:48 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
