Vinyl Siding Above Pitched Porch Roof - How To Secure The Bottom Of The Siding? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 10:48 PM   #16
Originally Posted by ExteriorRes View Post
Another option would be to install a "Starter" just like you have at the bottom panel of the house. This gives you a clean look and it doesn't collect any water.
The bottom lip of the first course was cut off because the roof started too high, so a Starter strip couldn't be used.
the only option in this case was to use J channel!
Old 06-14-2010, 10:51 PM   #17
firehawkmph's Avatar
Rewards Points: 1,866
Wildie,
One other thought comes to mind. I have used a piece of finish trim instead of the J channel in a case like this. You have to be careful when you nail it to keep it straight, it's not as ridgid as the J channel. It doesn't collect water, fits a lot snugger.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-14-2010, 11:15 PM   #18
Originally Posted by firehawkmph View Post
Wildie,
Mike Hawkins
Can you be more explicit on what you meant by 'finish trim'? The OP may find this idea to be useful.
Old 06-15-2010, 05:30 AM   #19
kwikfishron's Avatar
Rewards Points: 410
Originally Posted by kwikfishron View Post
It could have gone in “Utility Trim” . If you look under the bottom piece of J-Channel on your windows you should see a piece of UT. J-Channel looks better though.
I wouldn’t worry to much about it if your roof is done right. You have the same thing going on above your windows. Where does that water end up?
For piece of mind you can push back the siding and drill some 1/8” weep holes in the bottom of the channel every couple of feet or so.
First sentence of first reply.
Utility Trim, Finish Trim, it's all the same thing.
Actually, it would be “dbl. finish/utility trim” for Dutch Lap.
Nothing like a full circle thread.
kwikfishron is offline   Reply With Quote
Old 06-15-2010, 06:35 PM   #20
Here,
while we're at it, this should explain everything:
http://www.certainteed.com/resources/cts205.pdf
Mike Hawkins
Old 10-09-2010, 11:32 AM   #21
To give you peace of mind, I'd suggest removing the bottom piece of siding with a zip tool, running some self stick window/door seal under the siding and over the roof flashing, and then reinstalling the siding with the J channel. Don't let the seal be exposed to the sun as it will deteriorate over time
mrgins is offline   Reply With Quote
Old 10-09-2010, 12:42 PM   #22
Registered User
Rewards Points: 5,492
Gary in WA
Last edited by Gary in WA; 10-09-2010 at 07:13 PM. Reason: Mod forgot to show ad removed.
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 10:55 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
vinyl siding piece comes loose dderolph Building & Construction 3 11-03-2007 04:56 PM
