-   -   Vinyl Siding (http://www.diychatroom.com/f19/vinyl-siding-92810/)
Monae 01-19-2011 10:27 AM
Vinyl Siding
Dear Experts,
Since my house was built in 2004 I have had a critter of some sort living in my bedroom wall. They are nowhere in the house, only in the walls. I've hired six pest control/wildlife experts and while we have found some entry points I'm still plagued with this problem. One of the ways they're getting in is underneath the vinyl siding. I bought a fiber optic snake camera to see behind the wall and they are really doing some damage in there. They are in the wall where all of the electrical wires come into the house. It's amazing they have chewed on any. The fuse box sits below that wall in the basement.
I have a contractor working with me now and even he is stumped as to how they're getting in. I really need to know what I can put up underneatht he siding to prevent them from getting in.
Thank you,
Monae
WillK 01-19-2011 11:09 AM
From dealing with rats, we've filled holes with course steel wool and sprayed in expanding foam so that the steel wool will be embedded. But our exterminator advised us to only do this once the rats are gone because they don't like change and if we did it while they were still alive, we'd more likely see them trying to find another route which might include inside the house.
CplDevilDog 01-19-2011 12:35 PM
Mouse proofing a house that has already been built is a tall order. I never believed mice could climb brick until I saw one go zipping up 10' of brick wall on the corner of our home!
There are so many areas that, if they weren't properly detailed during construction, will either be near impossible to find or to expensive to repair.
Some possible ones:
1. Missing sheathing under the cantilever for brick facade.
2. Improperly sealed holes for service lines, drains, branch circuits, etc.
3. Garage doors that don't seat tight to the weather lip
4. Windows and doors installed improperly
I'm sure there a few dozen I'm letting slip.
When you consider a mouse can push through a hole the size of a pencil, you can see how hard it would be.
Traps, traps and more traps. Make the area around the home as unattractive to mice as possible. Remove brush, wood piles etc.
Dwoodsmith 01-19-2011 01:52 PM
Any rodent that eats dry grits will have their tummies explode and they will die. Trouble is- where they die they stink.
