Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 02:44 PM   #1
We are installing vinyl siding on our own, we are half way done the back wall and realized that the bottom piece of siding is not clicked into the starter strip... is there a way to fix this without tearing the whole wall of vinyl siding down?
It appears that half the wall is clicked in (we used 2 pieces) the first one is clicked in and the second one is a tiny bit too low.
Thank you!
4 threads on same issue merged
Moderator
hurley2010 is offline   Reply With Quote
Old 11-04-2010, 03:19 PM   #2
kwikfishron's Avatar
Rewards Points: 1,002
If I understand you correctly your first coarse of siding is two pieces wide and one of the two isn’t locked into the starter but the rest of the wall is fine. If this is the case just lower the starter strip.
kwikfishron is online now   Reply With Quote
Old 11-04-2010, 07:54 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
somethings out of level somewhere,if your starter was level and the siding is not hooked in then your siding is out of level,just dropping the starter won't fix that
Tom Struble is offline   Reply With Quote
Tags
siding , starter , vinyl
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
