-   -   Vinyl siding (http://www.diychatroom.com/f19/vinyl-siding-3590/)
TonyD 08-21-2006 03:43 PM
Vinyl siding
I have Alum siding and going to have it replaced with vinyl. UNder the old siding is the original shakes and then tongue & groove planking. Should the original shakes be removed & then the new siding installed or leave it on. What are the advantages or disadvantages of removing as opposed to keeping it.
Tony D.
redline 08-21-2006 04:55 PM
Why are you removing the aluminum?
Aluminum siding adds more value to a house.
Will you be putting up house wrap?
Will you have foam insulation under the vinyl?
TonyD 08-22-2006 01:48 PM
The alum siding is all dented and falling off. The installer said he would remove the alum and add a insulating board then vinyl. I was just wondering if I should have them remove the orig shakes down to the plywood.
TonyD
