Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 09:44 AM   #1
Vinyl Siding
We are going to be placing vinyl siding on our hunting cabin. I'm looking for help on establishing the starter strips. We will be covering existing wood siding and the elevations of the existing siding vary. The south side is the lowest. The west and north sides jump up approximately 18". Then the east side has three different levels to it. Should we use a starter strip on the lowest side and J-channel on the rest? A picture of the east side is included.
sthfrk is offline   Reply With Quote
Old 07-25-2012, 11:30 AM   #2
Rewards Points: 2,210
Anyway to bring it all down to the same elevation?
Attaching furring strips to the lower part of the walls?
And sometimes on older buildings things are not level, you want even not necessarily level.
mae-ling is offline   Reply With Quote
Old 07-25-2012, 01:17 PM   #3
We can't get everything down to the same elevation. Some of it we can make better, but we don't have room to get 2 of the sides down to the lowest elevation.
Old 07-25-2012, 01:38 PM   #4
How about putting it all at the same elevation then skirting below that?
Otherwise yes, starter on the lowest and J channel on the others. Drill weep holes in the bottom of the J.
Unless you can work it out so it land on another bottom, then use starter there also.
Say you have 10" siding, and the one bottom is (or can be made to be) 20" above, then you can use starter again.
Old 07-25-2012, 01:54 PM   #5
I think I am going to go with a J to make up for the difference. I think the siding is 8" and the difference is 20", so that idea won't work. Thanks for the input.
Old 07-25-2012, 02:05 PM   #6
will need to clean out the J from time to time.
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
