Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 06:50 PM   #1
vinyl siding
My kids installed vinyl siding on my house and was installed in the direction where the overlap is very visible. Can that be corrected without pulling the siding all the way off?
timbuck is offline   Reply With Quote
Old 08-25-2011, 05:52 AM   #2
kwikfishron's Avatar
Rewards Points: 794
Yes it can.
kwikfishron is online now   Reply With Quote
Old 08-25-2011, 06:22 AM   #3
the Musigician
DangerMouse's Avatar
Originally Posted by kwikfishron View Post
Yes it can.
So... were you going to tell us how?
....and timbuck too?
-=chuckle=-
DM
Old 08-25-2011, 07:02 AM   #4
Rewards Points: 794
-=chuckle=-
DM
I completely answered the question as asked.
1. Unlock the panel above the seam to expose the nails using your trusty zip tool.
2. Pop the seamed panels off the nails a few feet or so on either side of the seam.
3. Unlock the bottom of those two panels. They will now be flopping in the wind.
4. Reverse the seams.
5. Re-nail the siding.
6. Lock the panels back together using your trusty zip tool.
Old 08-25-2011, 07:22 AM   #5
the Musigician
Thank you!
I know it was fun trying to constantly remember to lap each piece the correct way on each wall I did.
(I just had to make the "timbuck too" joke..... Come on, you knew someone was going to.)
DM
Old 08-25-2011, 09:30 AM   #6
Rewards Points: 562
dm- not so hard,,,you start at fartherest corner and work forward or fartherest from door and work towards door as the case may be!!
4just1don is offline   Reply With Quote
Old 08-25-2011, 03:14 PM   #7
Rewards Points: 794
I will add… if you do want to reverse some seams don’t wait months or years to do it, unless of coarse you want to see just how much your siding has faded.
The Following User Says Thank You to kwikfishron For This Useful Post:
DangerMouse (08-25-2011)
Old 08-25-2011, 03:34 PM   #8
the Musigician
Good point, Ron. Especially if it's in the sun. Weeks could be noticeable.
DM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
