Vinyl Replacement Windows. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 03:47 PM   #1
Rewards Points: 81
Vinyl replacement windows.
Hello, I want to replace the old aluminum windows on the front of my house with vinyl replacement windows. I'm looking at the type where you just slide in the new window into the old frame since my house is stucco'd. I've been looking on-line and see a lot of mixed info on different windows and manufacturers. What I'd like to know, is there any window installers out there who can tell me which are the better vinyl windows? In other, if you were going to install vinyl windows in your own home what brand would you put in? I've read some negative reviews of pella and anderson but others say they are the best. On the other hand I've read good things about Extreme energy 3000 budget, and Schuco, etc. thank you
joefromcal is offline   Reply With Quote
Old 02-20-2011, 10:45 AM   #2
Retired
Edgar214's Avatar
Not a pro, I installed Anderson in my house. We've been very pleased.
Mike
THE ONLY THING THAT'S CONSTANT IS CHANGE
Edgar214 is offline   Reply With Quote
Old 02-20-2011, 11:14 AM   #3
Hi joefromcal,
I also live in So Cal., I have Milgaurd Tuscany installed in my house. The reviews on the web have been very good. I went thru COSTCO with one of the sub contracters they use and the price was right as well as the knowlege of the installation company. You may be able to go direct to the sub contracter, they are a large company in Santa Ana. I don't know how much I can post about them on the fourm.
NASCAR9 is offline   Reply With Quote
Old 02-20-2011, 12:42 PM   #4
Rewards Points: 81
Thanks for the response. Can you tell me what particular Anderson window type you had installed, for example, the Craftsman, 400 series, etc. and was it for doble pained with double or triple weather stripping? Thank you, Joe
Old 02-20-2011, 12:43 PM   #5
Rewards Points: 81
Nascar, thanks for the response.
Old 02-20-2011, 02:44 PM   #6
Retired
Edgar214's Avatar
It was the Craftsman.
Mike
The Following User Says Thank You to Edgar214 For This Useful Post:
joefromcal (02-20-2011)
Old 02-20-2011, 04:27 PM   #7
Check out Marvin's fiberglass windows
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
joefromcal (02-21-2011)
Old 02-20-2011, 04:27 PM   #8
marvin windows
marvin has a fiberglass frame which are the best here in az , im a window installer here for my money id check out the intergity window from marvin
wayne beresford is offline   Reply With Quote
The Following User Says Thank You to wayne beresford For This Useful Post:
Old 02-20-2011, 10:54 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
all the major manufactures now have insert or pocket type units made from all types of materials and cladding,you don't necessarily have to use a vinyl unit
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Leaking Vinyl Windows in 7 year old home c3uo Building & Construction 14 04-12-2011 10:02 PM
Replacement Windows lucky8926 Building & Construction 36 10-13-2010 12:09 PM
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 04:48 PM
Vinyl replacement windows First timer1 Building & Construction 6 04-30-2009 11:22 PM
Replacing mylar windows with vinyl windows turkeybday Building & Construction 1 03-02-2009 07:03 AM
