Old 08-22-2008, 10:45 PM   #1
Vinyl over fascia, how to finish overhang?
I have an older house with wide soffits, about 23 inchs. I am applying vinyl to the fascia boards but when I get to that "big triangle" on the end at each eave I am stuck. What is standard practice for this area? Aluminum sheet?
patrickogrady is offline   Reply With Quote
Old 08-23-2008, 04:08 AM   #2
Are you talking about this part of the facia. (red arrow)
James Con is offline   Reply With Quote
Old 08-23-2008, 05:36 AM   #3
Yes, exactly. I have a fairly large one. The vinyl I bought for the fascia board is about 6 1/2 wide, which won't cover it from the bottom up.
Old 08-23-2008, 06:36 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
that is what we here on the island call a pork chop!. It is covered with a aluminum trim coil. that we bend on a bending brake. you can not buy this piece pre-bent as far as I know. If your covering all the trim on your home with pre-bent alum. fasica trim. what i would recommend is rent the bending break from a tool rental or big home box store and pick up some coil stock for around 75.00 and bend everything your self. this way all the trim will match in color with no shade difference. good luck bob.
Old 08-23-2008, 08:00 AM   #5
I'll have the gutter guys do it then, they have the tools and materials already, thanks for the info!
patrick.ogrady is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
Roof sheathing overhang on fascia Clutchcargo Roofing 7 08-23-2007 02:02 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
