Vinyl Corners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 05:23 PM   #1
vinyl corners
I'm having trouble with a vinyl siding issue...the corners are tricky!
I have to overlap, but the fancy 3/4 corner profile means that once I get them snapped in, they look stretched. What's the secret?
Andrew
maxwell_smart00 is offline   Reply With Quote
Old 12-15-2011, 07:03 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
What do you mean "stretched"?
You don't want the siding fitting to tight, you know that, right?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 07:07 PM   #3
Rewards Points: 14,014
Just press it in as you start at the bottom.
Old 12-15-2011, 07:48 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
you need to notch the lower to receive the upper corner
http://www.certainteed.com/resources/CT205.pdf
see pg 28
Tom Struble is offline   Reply With Quote
Old 12-15-2011, 08:45 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
toms right, it makes overlapping em a breeze
woodworkbykirk is offline   Reply With Quote
Old 12-15-2011, 09:58 PM   #6
i get one every now and then
Old 12-16-2011, 08:18 PM   #7
That did the trick - thanks a ton!
One other quick question - I have 2.5" metal starter strip, and the panel doesn't seem to want to lock into the strip...do I have ot bend it out a bit, or is that a bad idea...
Andrew
Old 12-17-2011, 12:20 PM   #8
firehawkmph's Avatar
Rewards Points: 1,902
Don't bend it Max,
the vinyl siding is not designed to snap into the metal starter strip. You have to pull the panel up snug and hold it while you nail it.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Vinyl meets Cement (Hardie) Siding at corners WaldenL Remodeling 3 06-15-2010 06:18 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
